hey bigred, really if you want a good relyable truck, keep the EFI. it was designed to be alot more reliable than carbs. but you really need to know how the EFI system works. pick up a book at barns and noble called "Ford Fuel Injection, how to tune and modify" by carl probst. its a great book, very informative and it explains every part of the system. its a generic book, so it makes alot of refrences to smaller fords (probes, escorts ect) but its all in there. there is a COMPLETE list of 2 and 3 digit codes. and a detailed explaination of each component of the EFI system and EEC-IV.
i just thought id pass this on, i am 19 and sometimes think that carbs would be better too...but thats only when my efi is fouled up. but when it is working i wouldnt trade it for anything.
well then you can forget about going carbed. it would be way to expensive to go about getting the proper stuff to make it work. keep the efi and allow us to help you sort out the issues. you will be happy you did
just a little side note on this. Not to start an arguement or anything but Baumann Electronic Controls does manufacture a computer that is specific to electronic controlled transmisions like the E4OD. A currently have one of thier computers and valve bodies that I plan on installing into my Bronco. Thier tranny computer can be installed into rigs that have either Carburator or EFI. Baumann's computer is a stand alone retrofit setup. they do have instructions on thier web sight on the subject of the E4OD tranny and Carbed engines. I did post the web sight earlier, but here it is again http://www.becontrols.com/
Like kemicalburns said, stick with the EFI. Little better on fuel I believe.
hi everyone. for a long time now i have wanted to convert my 90 bronco from efi to carbed. yesterday, i was adjusting the timing and my engine caught fire! as i was putting out the 2 foot high flames, i decided to go with my idea of ripping out all of those "pointless" wires and sticking to the old style. my question is, do i have to change my cam that i just bought if im going to make the switch. also, wut manifold/carb combo do you recommend? i want somethin big and shiny. modest trucks are for wusses.
p.s.- i have shorty headers, a kickass intake system, and ambition.
thanks for reading and i would really appreciate any feedback
-Pat (17)
the engine in my 79 has a EFI head and it runs excellent with a carb intake and and a duraspark distributor. and it has ALOT more power than in did in the truck when it still had all the EFI stuff.
I also have a '90 Bronco. I am always trying to find ways to improve my truck. I concidered trading the EFI for a Carb... Then I noticed all the really neat trail buggies have EFI systems. The reason for that is simple, it works better.
Anybody can build a motor with a carb and slap it in a truck. However, that is returning to the stone age... My wife drives a '95 GMC Suburban. It is almost 9000 lbs., with a 350 EFI motor, & a 3.73 rear end. It gets 18.8 mpg, no lie. How? Simple, EFI and a 5 speed tranny. My Bronco gets 13 mpg with a 351 EFI and the crappy E4OD, & 3.55 rear end.
I am looking to steemline the EFI also, but I plan to replace the tranny with a much better unit. A stronger but more effient tranny. Because in the end we all have to buy fuel. You can cut it any way you want. EFI will save you money at the pump.
I vote keep the EFI..(just inc ase my vote counts!) When I bought my 86 I did'nt think I would ever be able to work on it...turns out I was dead wrong. Bought myself a manual and along with this board and many more like it...I have been able to fix EVERYTHING on the truck thus far (need some wood to knock on at this point).
Some suggestions to clean up the engine bay:
1) Wire loom all existing wires under the hood, also a good opportunity to make sure you have good wiring.
2) I got rid of the A/C stuff, never worked since the day I bought the truck anyway (besides is'nt a window down at 55mph considered "air conditioning"?). Kept it just in case I have the time and funds to fix the system. Anyway you would be surprised how much space a bracket, compressor and hoses take up...I can actually get to my oil filter from the front top of the truck now! YIPPIE!
3) Thinking about doing a conversion with the dual catalytic converter system. If/when I do it I can potentially get rid of the air pump freeing up more space.
tite 4x4 , how much for that setup . and why are you needing to use it .
With the new Baumann's tranny computer, E4OD valve body, and bigger tranny pan came out to about $400, if I remember correctly. I ordered it awhile ago and haven't had a chance to install it yet, since my Black Hole(Bronco) is my daily driver right now.
I am doing this setup for 2 reasons:
1) the stock computer is programed for both the engine and the Tranny, which is programmed for the bare minnimum, basically for mall cruising. The stock programming for the tranny seems to be very soft and mushy.
2) I had upgraded to the mass air flow conversion for the engine which came with its own computer just for the engine. which left me with two computers. The new computer just for the engine and the stock oem computer was left in place to control the tranny
End result, after I install the Baumann's computer for the tranny, better shifting and opperations.
The conversion to mass air flow and sequential firing, instead of bank firing, increased the performance on the engine now it's time for the tranny.
Another note about the Baumann's computer, is that it is fully prgramable through a desk top or lap top computer.
Good luck with the kit. would be good to know how well it works for you. especially on a stock tranny. being a 90 model e4od i would have about 2000 bucks handy when that tranny lets go. up till 93 that tranny had lots of problems and was very weak. you start increasing the shiftpoints and firmness and you may have problems on your hands . not to rain on your parade but thought i would let you know early rather then later
well tomorrow i should be finished with my beast. today i got my comp cam, gears and chain in.
I am wondering why you are throwing parts at this truck without properly troubleshooting it? You should listen a little closer to what Kem is saying, he makes good sense. I am waiting on the parts to get rid of the carb set up an run the fuel injection.
I see no rain and the parade, well maybe when I was younger. But since I've already talked to quit a few people and have done some research on this, so when I accually do get to pulling my E4OD tranny out to rebuild it, it will no longer be a stock 1990 E4OD specs. I am planning on building it to the most current specs possible. And since I no longer trust any of the local tranny shops around here, I'll be doing the work myself. That way I know exactly what is going into my rig. I will be posting another thread when I get to it and finish the rebuild.
All things being equal, there is no bashing here. Everything that has been said so far, is very informative, even for me. And, since I have done some research on the E4OD, that maybe I could share a little of what I have learned.
I Learned something. I have heard good things about the stand alone computer for the E4OD. They are a very strong tranny when re-built with all the upgrades. Please let us know how it goes, as far as difficulty and the outcome.
Al
