Squeaking Noise Ranger
Old May 8, 2005 | 09:42 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome dilly54, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 8, 2005 | 10:22 AM
rebturtle's Avatar
rebturtle
Originally Posted by dilly54
Is there anything else I can check in relative time, as I really don't have a place to live if I need serious mechanic work done. Or does the u-joint take a long time to replace? I do not have a garage so I can really only check stuff out in the parking lot of the college. Thanks for any information.
An easy way to check the U-joints is to crawl under the truck and grab the driveshaft. Twist it back and forth and try to shake it side to side at the joints. You should be able to feel any slack in the joints. The driveshaft may have about 1/8 turn of play in it. This is okay. The slack you're looking for is in the U-joints themselves, so try to isolate that if you can.
U-Joints run about $20 a piece for good ones, but if you've never changed them before and don't have the tools/garage, I would suggest having it done at a shop. If you take your 4x4 out to play, it wouldn't hurt to ask if you can watch them. U-joints are a common trail-fix item for almost all trucks/SUVs due to high loads in low gears and physical damage, and it could come in handy knowing how to replace them. You might just have to help fix a Chevy one day!!
Old May 8, 2005 | 09:46 PM
fawey1's Avatar
fawey1
the ujoint replacement at the garage was $120.00 total. Hope this helps.
AkF250HD
Aug 7, 2013 06:31 PM
WickedSharp
Jan 13, 2011 09:10 PM
mikesmayhem
Feb 25, 2010 09:19 PM
mikecox1
Mar 23, 2009 01:49 PM
coglesby
Dec 2, 2004 06:16 AM
