Heater Blower Question?
Old Apr 26, 2005 | 12:17 PM
bcboy4ca's Avatar
bcboy4ca
Hi everyone. For some reason no matter where you put the selector (floor,vent,mix,defrost) the air only blows out of the vents. I have done a search and tried to use the information I found to fix it but haven't had much luck so far. All I am trying to do is get air to come out of the defrost. I pulled the stereo out and watched the vacuum actuator (sp?) and it moves everytime I move the selector rod so I don't think vacuum is the problem . I am really stumped and am hoping someone can give me some help. Thanks.
Old Apr 26, 2005 | 07:35 PM
Ultramagdan's Avatar
Ultramagdan
Which vehicle are we talking about? A moving actuator means the vacuum may be good but if the door is stripped, all the vacuum in the word will not move it.
Old Apr 27, 2005 | 12:04 PM
bcboy4ca's Avatar
bcboy4ca
I'm sorry, the vehicle is a 1981 Bronco 351M with Air. Where is the door you are talking about located? I appreciate any help you guys can give me.
Old Apr 27, 2005 | 05:18 PM
Ultramagdan
I know some of the late model trucks have a blend door issue (as you noticed by the threads) and yours sounds similiar to it but I didn't think that was an issue with your year. IT's also possible the actuator you are looking is a different one. I would expect the blend door to be behind the glove box.
Let's see if anyone else can help you out.
psychlopath
15
Feb 1, 2021 10:32 AM
CurtisNova
Feb 24, 2014 10:32 PM
turnkyle
Feb 1, 2014 05:57 PM
cbrcassio
Apr 20, 2013 05:11 PM
dagray3
Dec 1, 2005 07:38 AM
