Bad PCM?
Old 08-14-2000, 06:27 PM
keence's Avatar
keence
keence is offline
Bad PCM?
Hi everyone, thanks for the help I've received here in the past few weeks.
However I have another one. On my 93 F-150 5.0 EFI AOD I'm getting codes:
#84 EVR Selenoid Circuit Failure.
#33 EGR Valve Position Sensor or Pressure
Feedback Sensor indicates EGR valve is not opening or not seated properly. (Closed)
I swapped the EGR and EVP with a know working system.
Purchased a new EVR and I'm still getting same codes. I unplugged the PCM and checked pin 33 and sig ret. line to EVR - No opens or shorts.
Could this mean my PCM is faulty? I called and the Dealership said $225.00 - $235.00
Thanks for any help.
Brian & Kathy
Old 08-14-2000, 08:03 PM
hotrodford_88's Avatar
hotrodford_88
hotrodford_88 is offline
Bad PCM?
Do you have a code scanner? If so, then there should be a section on clearing the codes from the memory. I think this is what you need to do. If you don't have a reader, then pull off one of the battery cables. This should also clear the codes out of your computer. You do have to leave the cable off for about 10-15 minutes I think in order for the codes to clear. (like I said "I think")
Clearing the codes should help with your problem. I know mine seems to run better, when I disconnect the battery whenever I'm working on something electrical on it.
Hope this helps.
Old 08-14-2000, 10:40 PM
keence's Avatar
keence
keence is offline
Bad PCM?
Thanks for the reply. I have disconnected the battery several times in the last week. Once even overnight, but the check engine light still comes on and my code scanner gives me #84 KOEO and #33 KOER.
Thanks again,
Brian & Kathy
Old 08-15-2000, 07:01 AM
TallPaul's Avatar
TallPaul
TallPaul is offline
Bad PCM?
mpmccarthy
08-21-2011 09:16 AM
peter_x
16
07-15-2011 07:45 AM
mdfudge
Modular V10 (6.8l)
02-16-2011 11:31 AM
bcdeines
02-01-2005 03:19 PM
Quick Reply: Bad PCM?
