frame shorten
Old Apr 26, 2005 | 07:14 AM
six7seta's Avatar
six7seta
frame shorten
well its about to make my F2 back to an F1, but i need to know the distance from the back of the cab to the center of the rear axle.... so if someone doesnt mind running out side with a tape mesure i would be thankful.
Old Apr 26, 2005 | 04:24 PM
himmelberg's Avatar
himmelberg
Wouldn't it be more accurate and simpler to move your rear axle to the wheelbase that you want? Or subtract that amount from your frame? Perhaps I don't understand what you are doing. Good luck with it anyhow.
confused, himmelberg
Old Apr 26, 2005 | 06:31 PM
4tl8ford's Avatar
4tl8ford
Hey Six
Your frame needs to be cut in two places. Do a search we had all the numbers laid out about a year ago.
Old Apr 26, 2005 | 08:18 PM
six7seta's Avatar
six7seta
well im putting a 4 link in so i was just going to move it up to the correct spot and cut off what i need from the rear.. just seems to be the simplest thing to do
Old Apr 28, 2005 | 02:34 PM
55 F-100 PAUL's Avatar
55 F-100 PAUL
Suggestion
I dont have a F-1 so I cant measure for you but could you use the wheelbase of the F-1(114") and measure 114" back from the center of your front axle.
Good Luck,
Paul
Old Apr 28, 2005 | 05:10 PM
4tl8ford's Avatar
4tl8ford
F1 6 1/2 ft Pickup
Rear of cab to cl rear axel 39.74 inches
CL rear axel to rear end of frame 39.02 inches
Remember if you ARE not going to cut it to the F1 Specs you are going to have to work around the frame kickup.
Shaneb75
Dec 5, 2013 05:10 PM
NtShade
Aug 8, 2011 10:45 PM
hifiman
Jun 29, 2011 06:45 PM
joe f350
Aug 15, 2009 06:58 AM
krol
Offroad & 4x4
Jan 28, 2007 04:32 PM
