Speed Sensor ?
Old Apr 25, 2005 | 04:15 PM
cal55's Avatar
cal55
Speed Sensor ?
Replacing speed sensor on 93 F350 4wd. O.D. light sometimes flashes. When I pulled old one out end was broken off. Removed cover and cleaned out. When I install new one does the end have to be turned a certain way or does it turn all the time? What is the torque on the rear end cover bolts? Thanks !! Any other things to look for in changing this sensor?
Old Apr 25, 2005 | 04:34 PM
deanj's Avatar
deanj
The speed sensor will only fit one way. The bolt that holds the sensor in (think it is 1/2) is threaded into the diff.
Old May 1, 2005 | 06:20 PM
cal55's Avatar
cal55
Wrong speed sensor
Was given wrong sensor. Had to go to Ford to get right one. Only 23 dollars. Part # F85Z-2L373-AC
Old May 2, 2005 | 06:37 AM
PLC7.3's Avatar
PLC7.3
Cover plate torque....28-38 ftlbs
RABs sensor bolt ........25-30 ftlbs
Kingfisher591
Sep 26, 2012 08:58 PM
redsly
1997 - 2003 F150
Jul 10, 2012 07:39 AM
LonnieD
Sep 22, 2010 01:18 PM
Hondo Sackett
17
May 28, 2010 04:13 PM
mrminn
Mar 15, 2004 07:19 AM
