I've seen hoses or tubes running to & from egr's clogged shut like arteries.
To remedy this I've removed them & used (depending on the tube or hose) drilling, pipe cleaners or bent the hose & rolled it until powdered carbon poured out & I could see through it again.. eventually I just changed out the hose since it is cheap & could then be ruled out as a vacuum leak in the process..
Assuming that the vacuum lines to the EGR valve are working properly: I too have experienced the EGR port carbon up. Best way to clean it, IMO, is to remove the valve and chuck up a piano or guitar string in your drill, place the string in the hole and "let 'er rip". Best to have a buddy hold the shop vac hose near the port to suck up as much of the residue as is possible.
Also check the tube from the exhaust to insure that it is clear.
I'm in the same situation as you bwoolston16. I've replaced everything (including the 2 hoses to the position sensor) but the solenoid. I've done everything but clean the metal exhaust tube between the EGR and the manifold. I've subscibed to see if you keep us posted, I'll do the same.
I disassembled mine again this weekend. Cleaned the intake port and the exhaust line to the EGR valve. No luck, it still gives the insufficient flow code and stumbles. The only thing I have not replaced is the EGR vacuum solenoid. The part number (i think) that I could visually identify is FOTE-A1A-9J459. Is this correct and can anyone find a replacement part for it? I tried the internet with no luck.
Check out motorcraft or rockauto.com, they'll show the part number.
I checked those places but it can be confusing. The rockauto.com had the EGR regulator solenoid listed but had a picture of the EGR position sensor. To help out, I found a picture of what it is I think I may need. The Item is not from a Ranger, but it is almost identical in shape and size.
