Insuffucient EGR flow
Old May 10, 2005 | 07:41 AM
jinx102672's Avatar
jinx102672
I got the solenoid yesterday and installed it. I disconnected the battery to clear all codes then went for a test drive. Retested the comp. with a code reader and all EGR system components are good. I'm no longer getting the insufficient flow code. My guess would be that the electronics of the solenoid were in working order and not throwing a code, but the internal valve of the solenoid was malfunctioning or clogged.
Thanks for all the help.
Now I have a another problem. The truck still wants to stall. When I re-read the codes, the EGR system was clear but it came back with the following 2 codes:
KOER 172 - HEGO sensor fault/lean
KOER 411 - Can not control RPM during KOER low RPM check.
Any ideas???
Old May 10, 2005 | 08:41 PM
Ken00's Avatar
Ken00
The stalling problem (code 411) is probably the IAC, I would run the pinpint tests.
The 172 could be due to a defective O2, vacuum leak, exhaust leak, low fuel pressure bad wiring, dirty MAF, EVAP problem. Again the pinpoint tests would help.
Drop me an email if you need a copy of the tests, please remind me about your truck & codes.
Old May 11, 2005 | 08:03 AM
jinx102672's Avatar
jinx102672
Thumbs up It's all good
I went to the parts store after work with my codes and my problem. They sold me a TPS and an O2 sensor. I replaced the TPS first, reset the computer and drove it around to warm it up. I hooked up the code reader again, before I attempted to change the O2 sensor.
KOEO = 111
KOER = 111
So from what I can tell, my problems were:
Faulty EGR valve position sensor (clogged)
Faulty EGR valve solenoid (clogged/mechanical malfunction...it did not throw a code because the solenoid portion of it was still functioning properly.)
Faulty Throttle position sensor (150,000 mile wear-out)
It's running smooth now and the Idle positon screw is backed out almost all the way, where it should be.
Thanks for all the help guys and on a side note...
I finally located my PCV valve (it's in the weirdest place)
Old May 11, 2005 | 07:40 PM
Ken00's Avatar
Ken00
I recommend never adjusting them but if you have adjusted it I would want the rpms to drop down to 400rpm when the IAC is disconnected.
Al_Cuevas
1997 - 2003 F150
93
Aug 13, 2016 08:50 AM
Tommy28097
1997 - 2003 F150
Jan 16, 2016 11:17 AM
davenpt
2004 - 2008 F150
21
Jul 7, 2014 01:33 PM
Bert01F150
3.8 & 4.2L V6
Jun 29, 2009 10:23 PM
irishguyincc
Jun 4, 2006 11:31 PM
