1978 - 1996 Big Bronco
Bucking Trans
Old Apr 25, 2005 | 02:26 AM
Fordbyford's Avatar
Fordbyford
Exclamation Bucking Trans
I don't know if this is normal or not but when even I shift into drive or reverse with my automatic tans she bucks alil bit Ill hold my foot on the brake and Ill shift her from Park to drive then she pushes foward a little bit same thing in reverse like i said before Im not sure if ita normal or not but I just wanted to see if anyone had the same issue if you do tell me if theres away to fix it if fixable at all thanks~KYLE
Old Apr 25, 2005 | 06:25 AM
scurbiedog's Avatar
scurbiedog
Sometimes if your idle is a bit high it will do that but if its not check your modulator valve,fluid level,and how long has it been since you changed you screen in there?
Old Apr 25, 2005 | 10:54 AM
Fordbyford's Avatar
Fordbyford
I had just recently bought it back in november of 2004 and I just 80,600 yesterday so I havent changed it yet but will look into it
Old Apr 25, 2005 | 11:05 AM
Kemicalburns's Avatar
Kemicalburns
what year,motor,tranny do you have. this will help us make a better diag
Old Apr 25, 2005 | 11:42 AM
Fordbyford's Avatar
Fordbyford
Sorry kinda forgot about that Its a 96 5.8(351W)XLT automatic trans
Old Apr 25, 2005 | 12:29 PM
Kemicalburns
so we are talking about the e4od. when was it serviced last with filter/fluid change. also check for codes that tranny is electric so it will store codes if there is a problem
MotherWolf
Nov 26, 2014 05:08 PM
Texas Chain Ring
Sep 28, 2012 09:14 AM
Texas Chain Ring
29
Sep 22, 2012 12:03 AM
shanes_cool
18
Nov 10, 2007 05:59 PM
