cut my frame
Old Apr 24, 2005 | 08:51 PM
tomoto's Avatar
tomoto
cut my frame
shorten my frame today 58 inch from wheel to wheel .it looks so cool can't wait to put the cab on .. 1948 coe with a 6 foot bed...motor done ,mustang 2 front on, ZR2 rear axle with disc ,looks like the drive shaft is going to be 2 1/2 foot long ...
Old Apr 25, 2005 | 08:04 AM
AXracer's Avatar
AXracer
WOW! That's a really short wheelbase. Are you going to be towing a 5th wheel with it? If not, I hope you don't find it too twitchy to drive or so top heavy it wants to roll over. Don't forget pics!
Old Apr 25, 2005 | 09:10 AM
7fords's Avatar
7fords
how did you make your cuts? did you step the cut for strength or did you cut straight from top to bottom?
Old Apr 25, 2005 | 01:38 PM
51dueller's Avatar
51dueller
AXRACER they did make 110" wheel base COE. They would have a short driveshaft.
Old Apr 25, 2005 | 02:51 PM
AXracer's Avatar
AXracer
110" is a LOT longer than Tomoto's 58"! Even if he actually means between the outer diameter of the tires that may add another 30" for 88" that's still REALLY short. Even with a COE cab it sounds like the rear wheels will be right behind the cab?
Old Apr 25, 2005 | 03:21 PM
51dueller's Avatar
51dueller
I thought he shortened it 58". He says 1948 COE with a 6 foot bed in the first post.
Old Apr 25, 2005 | 06:08 PM
4tl8ford's Avatar
4tl8ford
I don't intend to be mean but a 58" wheel base sounds like an "Outhouse on Castors"
That will be one wild and whooly ride.
Old Apr 25, 2005 | 06:25 PM
AXracer's Avatar
AXracer
If he shortened it by 58" how long is the stock wheelbase on a COE? Even shortening a limo's wheelbase 58" would make it pretty short...
PS: there's a small pic of a custom COE pickup in this month's issue of Rod and Custom.
Old Apr 25, 2005 | 07:12 PM
51dueller's Avatar
51dueller
They came in 110", 134" and 158". He probally has the 134" wheel base because you can just fit an 8 foot box on the 110" wheelbase. He would have about a 76" wheel base.
Old Apr 25, 2005 | 07:54 PM
4tl8ford's Avatar
4tl8ford
From the center of the front wheel on a COE to the rear of the Cab it is 49.94 inches.
From the Center of the rear wheel to the front of the bed of an F1 with the 61/2 ft bed is 39.74 inches
That makes 87.66"
An Outhouse on Castors.
Old Apr 25, 2005 | 09:28 PM
tomoto's Avatar
tomoto
its a f-1 frame with 27 inch remove behind the cab ,and i'm putting a 48 coe cab with a 6 1/2 foot bed and its 87 inchs wheel to wheel
Old Apr 25, 2005 | 11:14 PM
AXracer's Avatar
AXracer
Good luck with it, 87" is shorter than an old VW beetle.
Old Apr 26, 2005 | 07:16 AM
Christopher2's Avatar
Christopher2
Veteran: Navy
I hope that truck is lowered to the ground with wide tires so it does not tip over like a Suzuki Samari.
Old Apr 26, 2005 | 08:36 PM
tomoto's Avatar
tomoto
frame rail is going to be 8 inch off the ground, the trans is 5 inch to the ground
Old May 5, 2005 | 04:03 PM
7fords's Avatar
7fords
dont know why everyone thinks sammys tip easy ive own two of them lifted and big tires never even can close to tipping even with my crazy driving
