brake bleeding
Old Apr 25, 2005 | 04:09 PM
Madathlon's Avatar
Madathlon
Originally Posted by MIKEDEL
One more question. I installed the check valve so that the convex portion was inside the spring. Is this correct or did I install it backwards?
That I dont know.. I just replaced my MC .. I dot like rebuilding my brake system parts.. Safer just to replace..
Old Apr 25, 2005 | 07:20 PM
MIKEDEL's Avatar
MIKEDEL
I would have replaced it also but I couldn't get it un-bolted. I couln't get a wrench behind the bolt closes to the front of the truck.
Old Apr 25, 2005 | 08:18 PM
Madathlon's Avatar
Madathlon
Ahh.. that make more sense now.. How about a plasma cutter?...
Old Apr 25, 2005 | 09:22 PM
jvmcc's Avatar
jvmcc
You bled them in order with the wheel most distant from the master cylinder bled first working to the last one which would be closest to the master cylinder? Sometimes the bleeding order makes a difference.
IDIDieselJohn
21
Oct 18, 2015 06:38 AM
93XLT150
Feb 13, 2011 05:51 PM
kermmydog
Nov 7, 2007 08:04 PM
BigSix1
Nov 24, 2004 09:59 AM
rwt
May 27, 2003 06:23 PM
