Front end Help
Old Apr 24, 2005 | 05:49 PM
foxcougar460's Avatar
foxcougar460
Front end Help
Hi, I have a 76 F-150 4x4. About a month ago the driver front tire started jumping off of the ground if I went over 50 mph, and has since gotten worse and started doing it at lower speeds. I've replaced shocks, stabilizer shock, wheel bearings, and had the wheels rebalanced. Can anyone here help me out and think of something else it could be. Any help would be appreciated.
Old Apr 24, 2005 | 07:11 PM
willow_tree's Avatar
willow_tree
full time or part time 4x4?
Old Apr 25, 2005 | 07:48 AM
foxcougar460
part-time 4x4, 360 motor, 4-speed tranny, 31 inch tires
Old Apr 25, 2005 | 09:14 AM
73Custom's Avatar
73Custom
My first guess would be bad tire/rim. Swap that tire with the rear one. See if the jumping moves to the rear.
Marty
Old Apr 25, 2005 | 02:55 PM
foxcougar460
i've run two sets of tires and wheels and still have the same problems, the first set was some little 15's, then I went up to the 31's on 16's that are on it now
Old Apr 25, 2005 | 03:16 PM
73Custom's Avatar
73Custom
Check the ball joints and tie rod ends.
Marty
Old Apr 25, 2005 | 05:12 PM
willow_tree
is your front hub engaged. is it unlocked but still turns the front axle shaft. to check this, lift up the front end on that side with a jack and turn the tire and look to notice if the u-joint is turning or not.
Old Apr 26, 2005 | 07:46 AM
foxcougar460
it looks like it might be the ball joints, the tie rods are in good shape, and no, the hub is not engaged. The ball joints are worn, but they really dont look bad enough to cause this.
