Bigger Tires??
Old Oct 17, 2001 | 08:31 PM
tjm0's Avatar
tjm0
Bigger Tires??
Hey everyone... I have a question that hopefully someone will
beable to help me out with.. I have a 92 Ranger STX with i'm
guessing stock P235/75R15 tires/rims on it and I'd like to go
to a bigger tire..
Does anyone know what the biggest tire would be that I could
fit onto the stock rim without having any problems with rubbing
or will I have to get new rims? I don't really use the Truck
for off road, but am planning on eventually adding a minor
lift to the truck down the road...
Any help would be appreciated.. Thanks in advance..
Terry
Old Oct 17, 2001 | 09:55 PM
weldman's Avatar
weldman
Bigger Tires??
Well here's some info from dunlop:
http://www.dunloptire.com/products/tire.html?tire=radial_rover_rv
Your LT235/75R15 is 29.0 inches high and 9.0 inches wide.
You could go with a 31x10.50R15 which is 31.0 inches high and 11.0 inches wide.
There is a size between yours and the 31x10.50 and of course there are sizes a little larger! Check out the link.
I am assuming that yours is a 4x4.
I am unsure that these will fit for sure, what do you think guys?
Matt
1978 F250 4x4 - 351M
Don't crush them, restore them!
Old Oct 17, 2001 | 11:30 PM
rocky's Avatar
rocky
Bigger Tires??
This last weekend I saw a Toyota Land Cruiser with 23" RIMS! The guy paid $7,200 for the rims and tires. Darndest thing I've seen for a long time.
Old Oct 18, 2001 | 04:57 AM
Greywolf's Avatar
Greywolf
Bigger Tires??
I think a 3" body lift first, then a set of 35X15X15 mounted on steel rims would look pretty good on it. But the axles it has will determine max tire diameter. The bigger the tires, the more likely a broken shaft at some point. It's a ranger - how big would you go?
Old Oct 18, 2001 | 06:23 AM
DannyP's Avatar
DannyP
Bigger Tires??
cfgardei
New Member Introductions
Sep 5, 2017 06:41 AM
cyretired2
May 4, 2017 10:59 AM
Chumbucket
Oct 27, 2006 07:15 PM
kbcapecod
Aug 12, 2003 01:18 AM
trouble
Mar 1, 2001 07:05 AM
