high idle
Old Aug 30, 2000 | 10:43 AM
baurley's Avatar
baurley
high idle
I have been battleing an idle problem on my 91f150 5.0 5speed for the last couple of months. the engine wants to idle around 1700 rpm. so first i cleaned the idle air bypass valve nothing happened .then i replaced it, again the same high idle. i have changed the o2 sensor , the thermostat , the air intake temp sensor, the coolant temp sensor, andstill it does the same thing.what is the problem could it be the throttle position sensor.
your help would be appreciated.
Old Aug 30, 2000 | 03:29 PM
blueford's Avatar
blueford
high idle
I had the same problem on my 86 F150 5.0 and I changed the throttle position sensor and that fixed the problem.
Old Aug 30, 2000 | 03:49 PM
Boykinfan's Avatar
Boykinfan
high idle
It’s so basic but you’d be surprised how many people don’t reset the computer after a repair by disconnecting the battery for a few minutes. It makes all the difference in the world. If you’ve done it, disregard this, if not, give it a try!
Good luck!
Old Aug 31, 2000 | 10:27 AM
PAUL_2's Avatar
PAUL_2
high idle
Check for vacuum leaks . Also , Ive seen some throttle bodies that even after being cleaned would still stick the throttle plates open a little because sometimes its hard to clean carbon that builds up throttle plate shaft. Sometimes the best way to clean a throttle body is to remove it & clean .
Old Aug 31, 2000 | 10:34 AM
hoppy's Avatar
hoppy
high idle
You don't have to disconnect the battery to empty the computer's memory, simply run the codes and pull the test wire connection apart and this clears the codes without clearing the radio presets and clock.
Old Aug 31, 2000 | 11:06 AM
hoppy's Avatar
hoppy
high idle
Old Aug 31, 2000 | 01:34 PM
moley's Avatar
moley
high idle
Sais13579
Oct 24, 2024 04:22 PM
lazykranch
1983 - 2012 Ranger & B-Series
Dec 6, 2009 10:25 AM
texas zeke
Modular V8 (4.6L, 5.4L)
Aug 31, 2008 11:27 PM
weswes01
Nov 12, 2007 09:08 PM
allmyfords
1978 - 1996 Big Bronco
Mar 17, 2004 08:00 PM
