confirm rear axle code please
Old Apr 24, 2005 | 10:54 AM
lwong's Avatar
lwong
'97 Expy XLT, rear axle code 17, according to all the information floating in cyberspace, this is a 3.31 open diff, right?
I want confirmation because the tech section article doesn't even list my '98 Expy's axle code (H6) and this place http://www.drivetrain.com/noslipfordtruck.html claims that the '97 year axle code 17 IS a LS rear end.
Anybody have a definitive answer?
Old Apr 24, 2005 | 08:09 PM
j1993's Avatar
j1993
take a look under the truck there will be a metal tag attached to one of the differential cover bolts most likely the upper right side . the first three numbers are the ratio and if there is a number then a "L" followed by the other two numbers it is a limited slip.hope this helps?
Old Apr 24, 2005 | 09:12 PM
Monsta's Avatar
Monsta
Sit. Stay.
All Ford truck axle codes that begin with a letter are Limited Slip. Two numbers indicate an Open Diff.
Old Apr 25, 2005 | 04:34 AM
lwong's Avatar
lwong
That is my first choice, but it's the F-I-L's truck and he's 40 miles away, plus, he's 75 years old and not keen on crawling around under his rear end (!)
I had him look at his door tag and it says 17, anybody...anybody...
Old Apr 25, 2005 | 06:47 AM
wavinwayne's Avatar
wavinwayne
lwong,
I, too, have a '97 Expy. XLT. I have been researching this same info. I checked the axle code & mine is "17" also. I also checked the tags on the diff. cover. The metal tag on the passengers side is stamped: "S 802 C" then under that is "3.31 88 7E23". The metal tag on the drivers side is stamped: "Use 75w140 Synthetic Oil Only".
I have researched this till I'm blue in the face & I am 99.999% sure at this point that mine is NOT a LS rear end. Sounds like your F-I-L's is exactly the same. Hope this helps.
wavinwayne
Old Apr 25, 2005 | 08:43 AM
lwong's Avatar
lwong
ww, good enough for me, someone told him he had a 3.60 rear end, I thought that smelled funny, I'll set him straight
Old Apr 25, 2005 | 11:27 AM
TDN's Avatar
TDN
lwong, if your FIL has a manual for the 97 Expy, it should have the axle codes described in there as well. Or wavinwayne, if you have one, you could look it up too.
Old Apr 25, 2005 | 12:01 PM
wavinwayne's Avatar
wavinwayne
I will check the manual when I get home. It's my wife's Expedition. I don't recall seeing anthing related to axle codes in the manual, though.
If I do find anything, I'll post a pic of the page from the manual.
Old Apr 25, 2005 | 12:08 PM
TDN's Avatar
TDN
Sorry, just found a 97 Expy manual online and it doesn't have the axle codes in it. Not sure why I though they were in there. Oh well.
Old Apr 25, 2005 | 01:16 PM
j1993's Avatar
j1993
If anyone needs to find out what their axle code means, here is a good site with probably all of them. http://www.drivetrain.com/Fordtrkratio_posidata.html
