degreeing a camshaft
Old Apr 24, 2005 | 08:59 AM
Greg 79 f150's Avatar
Greg 79 f150
Anyone one here ever performed a cam degree alignment on a newly rebuilt engine like a 351m/400 ? If so, which alignment is the preferable method for this engine, the .050 or centerline ? What if a person does not have the new cam's time card , can the alignment still be done accurately without it ? thanks
Old Apr 24, 2005 | 03:14 PM
mark a.'s Avatar
mark a.
.05 reading is the way to find the intake center line of the cam. Without the cam card I wouldn't adjust it, just run it straight up at 0.
Old Apr 24, 2005 | 03:31 PM
pcmenten's Avatar
pcmenten
I have degreed a cam. I had a cam card to use but I don't think it's necessary. I strongly encourage you to do this, especially with a 351M or 400. It's probably the smartest thing you can do for a 400, so don't skip this step.
I'd use the .050 to find where the lobe center is.
Old Apr 24, 2005 | 04:46 PM
mark a.'s Avatar
mark a.
Without knowing where the lobe center is ground, the only thing you will get for your trouble is knowing where it ended up. You'll have no idea where it is supposed to be. Say you go through it and find at zero it's at 114. If you had a card and it said 112 you know how much to move it.
Old Apr 24, 2005 | 05:25 PM
Greg 79 f150
Thanks for the replies , guys. My buddy that built the engine has the cam timing card, but its a 100 miles away with him. If he doesnt want to come back and help me get this engine going, I may try this cam degreeing myself. I have tried it all to this point ( see my thread " timing problem" ) . The engine will run for a short bit, then die. I did the push rod length check, they are o.k. It acts like all the valves are not opening/closing on time. If I cant get it going , it looks like I will just buy a reman and put it in, bite the bullet, and rack it up as one of life's bad experiences. If he wants to get p'd off about it, thats his problem, Ive about had it with the whole mess. thanks again
Old Apr 24, 2005 | 06:45 PM
mark a.'s Avatar
mark a.
If the timing gear marks are lined up it will run, degreeing isn't your problem. How did you check p.r. length ? Hows your cylinder p.s.i.? Does it run rough when it runs ? If it runs ok & then just quits I'd be looking into the ignition, if your sure it's getting fuel.
Old Apr 24, 2005 | 06:59 PM
Greg 79 f150
I used the method that 278broncos posted on my "351 timing problem" thread. Trying not to run two threads on the same topic, mods dont like that . If you want I can bump the OT back up, just to get up to date on it ??
Old Apr 24, 2005 | 07:10 PM
user 478546's Avatar
user 478546
Kinda sounds like the carb float and needle valve aren't connected and the fuel pump has to "push" past the valve to fill the bowl.
Steve
Old Apr 24, 2005 | 07:23 PM
mark a.'s Avatar
mark a.
Assuming your using a known good dist. I think the push rods are too long. If you want to try something that will cost nothing, then find a piece of sheet metal about .03-.04 thick, drill 16 5/16" holes in it and cut them out to fit under the rocker stands, beet them flat after you make them. Put them under the the rocker stands & tighten them back down & see if it makes any difference. This step must be elimimated before before moving on.
Old Apr 24, 2005 | 08:27 PM
Greg 79 f150
Will do . Is that .030 to .040 thickness set in stone , if not , what is the max thickness I can use ?
Old Apr 24, 2005 | 08:36 PM
mark a.'s Avatar
mark a.
I wouldn't use any thicker than .05 at the very most. You will probably hear some valves clattering. I wouldn't rev it up either, just see how it acts. If it makes a difference you'll know your on the right track.
Old Apr 25, 2005 | 12:19 AM
pcmenten's Avatar
pcmenten
Yeah, it's sounding like the valves are too tight. Shimming the rockers may be the fix.
Old Apr 28, 2005 | 05:06 PM
Greg 79 f150
I searched though my engine rebuild /parts receipts, and found out he put a Crane blueracer cam in it, so I got on line and ordered the Crane rocker shim kits for the 79 Ford 351m . I will report back my findings after I get them in and installed. thanks
Old Aug 4, 2015 | 12:13 PM
Dasher400's Avatar
Dasher400
Mother of all thread bumps
Okay guys, I have looked and looked but still trying to figure this out...
If I install a brand new camshaft and timing set do I still have to take out the 4 degree timing retard that was factory.
I am thinking about ordering this( http://www.summitracing.com/parts/sum-g6621-9 )timing set to make it easy.
So, with a whole new cam, do I set it to 0° (to take out the factory R4)? Or do I set it to A4 to take it to actual 0°?
Or what do you suggest? I haven't started looking at cams but I want to get this timing issue right in my head first.
Engine is complete stock rebuilt 10 years ago with about 12k miles on it. I have the Edelbrock Performer intake and carb going on it when I do the cam.
Old Aug 5, 2015 | 07:38 AM
Gary Lewis's Avatar
Gary Lewis
First, you do know this is a 10 year old thread? You really should start your own thread.
But, to answer your question, there are only two places Ford could have built in the retard - the cam itself and the timing set. So, if you replace the cam and use an aftermarket timing set there will be no retard. You should install the cam at 0.
