Bed Protection Question
A plastic bed liner is too slippery for my uses...but are there any pluses to it? I've seen some people put a rubber mat on top of a plastic bed liner.
Can a rubber mat be used with a Rhino sprayed-in liner or is this overkill?
Finally, is a rubber mat by itself enough?
Thanks --
DG
I'm going to go with a sprayed-on bedliner and a mat. Will have to look around...I know that there is a Rhino Liner place here in a town sort of near to me but am not sure about Line-X. Will find out tomorrow!
Thanks --
No functional drawbacks to the spray-in bedliners such as Line-X, Rhino, etc except the initial cost. Will likely run you $400-$500 all said and done. Does cover the side walls too, which is also a plus. Pitfall: doesn't provide the extra "ding and dent" protection that a plastic bed liner does.
Pluses to the plastic bed liners? Less expensive than spray-in; easier to move cargo in and out of; covers side walls and bed rails, depending on style purchased; provides extra protection against dents and dings vs. a spray-in liner or just a rubber mat. Pitfalls: scratches the bed, and the elements can still get b/t the liner and the bed, causing rust, etc.
Rubber mat on top of a plastic bedliner? I'm sure it's done, but moving cargo in and out of the bed while the cargo's on top of a rubber mat, to me, seems like the mat would bind-up as you push (or pull) on the cargo atop it. Maybe I'm wrong, but that's what I would forsee as happening with a high degree of probability, so I'd opt for bungee cords instead to hold the cargo.
Rubber mat only (no bed liner or spray-in liner): the most affordable option, but functionality may suffer severly with cargo ingress/egress, and the elements can still get b/t the mat and the bed, causing rust, etc.
To sum it all up: if you have the money, go with the spray-in bedliner. If you can resist the temptation to get the "colorized", matching spray-in, do so. Pick a stock color like black or grey, as most spray-in liner companies offer as their base price. Matching the truck's color with the spray-in bedliner "sounds" cool and all that at first, but personally I've never seen a truck that has it that looks good, IMHO. It's just "too much" of the same color & personally, I'd be afraid to use the bed like a truck is supposed to be used for fear that it would take away from the overall look (ie, if the paint isn't perfect throughout).
Just my $.02,
DS
PS - I forgot the most important question: What will you be using the bed for? Will the bed see alot of cargo? What type of cargo? If you're hauling hay cuz you live on a farm, that's one thing. If you're going to be hauling Lab supplies in boxes, I'd opt for the spray-in (sticker surface; will hold the boxes in place better than plastic). If you're only going to be using the bed every once in a great while and it's only to put your bicycle in to go for a ride, I'd recommend the rubber mat (easy to remove when not needed or not in use).
An additional $.02 worth provided at no extra charge!!! LOL...
Legitimate question, to be sure! I will mostly be hauling Lab training supplies (as in Labrador retrievers) and also one or more dog boxes made to safely carry dogs en route. In particular a dog box that sets in the bed near the cab and sometimes another one closer to the rear...these are made of stainless/aluminum/sometimes portions in wood. Somewhat heavy. Training supplies are all sizes and shapes. Also sometimes horse gear, my ATV, or my bike. (Ha...how'd you know!) And other odds and ends. Am considering a couple of fenderwell diamondplate storage/toolboxes but don't know about that until I actually see some in action in someone else's truck.
Thanks for the good advice.
