"Over Drive" button?
Old Apr 24, 2005 | 01:55 AM
dondon623's Avatar
dondon623
How can I tell if my "Over Drive" is on or off? I don't see a light or anything else to let me know.
Old Apr 24, 2005 | 01:57 AM
HammerFX4's Avatar
HammerFX4
there`s a light on the left side of your panel that comes on when you turn your od off.It`s in the tach,
Old Apr 24, 2005 | 10:43 AM
EnergizerBunny69's Avatar
EnergizerBunny69
O/D light location
When you turn on the truck.......look at the dash just in case to see if you have a bad bulb in there. All of the bulbs go through a self test at startup. Some of them stay on if you just put the key in the on position. In this position you can toggle your O/D button and should be able to see the light go on and off. On my tuck the light is located on the extreme left side side next to the battery guage and it says "O/D OFF". Also your RPM's will be ALOT higher at highway speed. Not to mention the fact that the motor will be screaming for relief. Hope that this helps you.
Old Apr 24, 2005 | 11:53 AM
Cincy F150's Avatar
Cincy F150
On my XLT, when you turn off the overdive, it says it is off in the righthand side of the message center next to the odometer readout. I kick it off when I am coming down the hill from my house to keep the truck from running up to 60 mph in a 35. The cops around here just love that hill.
Old Apr 24, 2005 | 09:31 PM
dondon623's Avatar
dondon623
thanx.......i'll check it.
Old Apr 25, 2005 | 08:35 AM
osbornk's Avatar
osbornk
The transmission defaults to overdrive on when you start it. You can't accidentally leave it out of overdrive.
