Hi guys, I have a 1995 f350 PSD, and the check engine light came on. All the parts store i called said that their scanner would not work on it.
I need to buy a code scanner so i can see whats going on but i dont which one to get. Please help.
Thanks in advance
ps, everything is stock except for not cat or muffler, its strait piped
A scanner is a good tool to have, but you may consider buying a tuner instead. It will read your codes and it will allow you to make performance changes also. The scanner and tuner both plug into the same connector.
