I searched the forums but couldn't find an answer so..........I ordered a bed Extender from Ford for my 2005 F150. It showed up but without any installation instructions. I called my local Ford dealership, said I would have to bring it in for install and pay........does anyone have the installation instructions for this? Thanks in advance.
Hopefully 2 special bolts were included with the extender- you need to install them in the bed near the tailgate- they just screw in . The instuctions on how to remove and install the bed extender are in the owner's manual.
My suggestion: Go to your dealer's lot with a tape measure, measure the height and diameter of the three holes on each side of the box on a factory-installed extender, then go home and install yours the same way -- not much more to it than that.
There are 3 holes on each side the middle one is the threaded hole- the hole above it and the one below it should have plastic bushings for the bed-extender pins
James
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
I just got an extender for the dealer with a bag of hardware. I guessing from the number of pieces that the extender fits multiple applications. The bag contained the 4 bushings and the two post/bolts but also included two nuts and an additional post/bolt that was much thinner but longer than the others.
