Oil & Lubrication
This oil is disgusting!!!
Old Apr 22, 2005 | 12:47 AM
There Goes The Neighborhood's Avatar
Question This oil is disgusting!!!
I personally changed my oil, @600 miles in a rebuild to Mobil 1 15w50. For the first week, every time I checked the dipstick, the oil looked new, clean, and smelled great(for oil at least). Now, after another 550 miles of moderate driving, I checked the oil, and it truly resembles tar. It smells, is thick as molasses, and black as coal.
My thoughts are, I switched to syn a little prematurely, but only on a cost standpoint, and my viscosity is a hair on the high side. Combined with the fact that there still may be a little bit of assy. lube left in there, which would make my very nice mixture that does a better job at sticking bricks together than lubricating the internals of my big block. So, next month, I will change, once again. This time, it will be a fresh 6 qts. of Mobil 1 10w30, and a brand new motorcraft FL-1A.
I'm just wanting some opinions and idea's. Did switching @600 miles hurt the motor any? It runs great, carries good oil pressure, and my favorite, almost pours freshly condensed water out the tailpipes.
Old Apr 22, 2005 | 01:45 AM
Ed's Avatar
Ed
In your case, I might suggest changing your oil filter now, and topping off with even a good dino, such as Mobil 5000. With your recent rebuild, you probably have a lot of diluted assembly lube, by-products, and even minute metal shavings, particles, all normal, and all present in a rebuilt motor. You can even go with a bargain oil filter just for this purpose. Then, next month you can go with a quality Motorcraft oil filter, when you change your oil completely. Also, you are smart going with 10w30 Mobil 1. I feel this oil will be much more efficient in your engine, delivering maximum MPG, and cold start pumping, which will vastly reduce wear in your engine. Mobil 1 is a excellent oil, I feel. ED
Old Apr 22, 2005 | 02:49 AM
mean jean's Avatar
mean jean
10w30 will make all the difference in the world....I'll go as light as 5w30 but thats's only 4 the winter months.
I won't change my oil without replacing the filter. It's money well spent.
I find every 3 months or 3000 kilometers is about right for many vehicles.
If you got the time, let it drain for a good hour before finishing the job. I find taking off the oil cap helps but maybe that's just in my head.
'96 f-150
inline 6
115'000 kilometers
Awesome
Old Apr 22, 2005 | 03:23 PM
jimandmandy's Avatar
jimandmandy
The initial 600 miles should have been plenty to flush out anything left in the engine after the rebuild. I wonder if the rings have not seated yet and you just have excessive blowby sooting up the oil. Delo, Delvac or Rotella should hold the soot if that is the case. If you used chromed rings, you should wait several thousand miles for them to seat before switching to synthetic.
Jim
Old Apr 22, 2005 | 04:53 PM
TxBrokenarrow's Avatar
TxBrokenarrow
might be off target here but did you install a valley pan???not sure what motor you have??if no valley pan oil will cook on underside of intake manifold
Old Apr 22, 2005 | 05:43 PM
Golfmore's Avatar
Golfmore
Basically, on a new engine/rebuild I would use Dino for at least 3K miles, then go to syn.
Old Apr 22, 2005 | 08:29 PM
ford390gashog's Avatar
ford390gashog
just to let you all know the new mobil 5000 is a sm oil and not made for old engines you never ever want to run a sm rated oil in a engine with a in block cam the oil provides no cam metal on metal protection all oil companies made the switch a few monthes ago but only use a sl rated oil and something like rotella t would work a lot better than mobil in your engine as for wear metals are concerned.
Old Apr 22, 2005 | 11:52 PM
I feel the SM clain is BS. That's like saying "If your engine was originally designed/built in the 60's, use only SA rated oils. SM is just a better protection rating, and I don't have a problem running it.
I now realize that going with the 15w50 was a huge mistake. After more research, thin oil is where it's at. Easier on startup, great thermal protection, and better mileage. There's no need to force the engine to work harder. When I get my next check(2 weeks), I'm changing from 15w50, to 5w30, the original spec'd oil for my truck anyway. More than likely, I'll probably see engine temps decrease, and for sure mileage will increase.
Also, synthetics are great, but, in my mind, since I'm changing it 2 weeks from now, I topped off with Mobil Clean 5000.
Old Apr 23, 2005 | 09:28 PM
ford390gashog
[QUOTE=There Goes The Neighborhood]I feel the SM clain is BS. That's like saying "If your engine was originally designed/built in the 60's, use only SA rated oils. SM is just a better protection rating, and I don't have a problem running it.
Also, synthetics are great, but, in my mind, since I'm changing it 2 weeks from now, I topped off with Mobil Clean 5000.[/QUOTE
Even the companies that make the sm oil warn not to use it in a flat tappet cam application because the zinc content needed is no longer in the oil oh and by the way sa oil is not from the 60's try the 20's cars in the 60's used se rated , oil next time learn your facts first.
Old Apr 24, 2005 | 12:35 AM
I find it interesting that all I missed on is the SA certification. The API label says
SM/CF
SJ,SL,................
So, since it is rated for both, I'll run it. besides, it was 1qt to top off, and it's getting 5w30 synthetic in a week.
Old Apr 24, 2005 | 11:19 AM
Saurian's Avatar
Saurian
I thought we've been over the flat tappet cam issue, and it was decided (as relative as a decision can be reached) that a good diesel oil like JT-8, Delo, or something like that would be best for a flat tappet. You can get the JT-8 in 10W30. I"ll wait for Rusty to poke his head in here.
Old Apr 24, 2005 | 03:33 PM
FERacing66's Avatar
FERacing66
I use 10-30 Mystik in my 66 352FE engine. It has an aftermarket Crane Cam in it, the diesel rated oil is best for 60's flat tappet cam engines.
penguinshockey
2004 - 2008 F150
Sep 5, 2014 10:45 PM
jhand124
Jul 16, 2008 05:03 PM
rustyfuryiii
Modular V10 (6.8l)
30
Nov 24, 2006 04:49 PM
2fords2
Oil & Lubrication
50
Feb 13, 2004 10:12 PM
Perry Sconzert
Oil & Lubrication
Apr 30, 2003 10:57 PM
