1978 - 1996 Big Bronco
TPS calibration
Old Apr 20, 2005 | 10:03 AM
woodys's Avatar
woodys
TPS calibration
Elsewhere in this forum, someone mentioned TPS calibration. I just installed a new TPS (as well as other sensors) but didn't find any mention of calibration procedures in my manual. It's a 1988 with 5.8L engine. Am I missing something, 'cause the truck's not running so well.
Old Apr 20, 2005 | 04:50 PM
iagainsti's Avatar
iagainsti
check out fordfuelinjection.com under the sensor section. Its gives a great write up on TPS issues.
Old Apr 20, 2005 | 06:01 PM
gjordan456's Avatar
gjordan456
If you have everything hooked back up you can still check the voltage to the TPS, it should read from .8 to 1.0 volt's, turn the key to the run position, not running, and probe the green wire with the pos. probe and a good ground with the neg probe, you will get a more accurate reading with a digatal meter, if it's off you will have to take off the TB and loosen the screws of the TPS and move till you get the proper volt, there really isent much adjustment there, but just enough to move it alittle bit...
Old Apr 20, 2005 | 06:05 PM
gjordan456's Avatar
gjordan456
also I should of mentioned, did you dissconnect the battery cables? this will reset the computer and sometimes it takes a few miles of driving for the computer to catch up with the new parts..
Onframe
Nov 23, 2013 07:41 PM
Lightning58
Mar 4, 2013 08:24 PM
1badshovel
Apr 17, 2011 06:01 PM
94FordGuy
Aerostar
Jun 13, 2004 04:22 AM
madmurdok
Computer Chips & Tuners
Jan 27, 2004 09:34 AM
