What "tune-up items" are needed?
Old Apr 20, 2005 | 12:22 AM
azwolfman's Avatar
azwolfman
Question What "tune-up items" are needed?
I recently purchased a 1989 f-150 supercab 4x4 w/ 5.8l EFI, c6 tranny. This truck sat for about 1 year in a garage. I replaced the plugs, oil and filter, air filter, battery, coolant. What else would you reccomend? The truck has dual exhaust but you wouldn't know it from the sound. I want a deep rumble , loud enough to sound like a 351W truck should but I dont want to blow the neighbors away. Eventually, I'll want enough lift to run 33's or maybe 35's, and I want to gain some horses and improve the mpg's if all this is possible. What suggestions?
Old Apr 20, 2005 | 09:49 PM
payner22's Avatar
payner22
i just did a tune up too i also did the distributar and rotor as well as i had a bad plug wire so i replaced that too now it has way more power
Old Apr 20, 2005 | 09:53 PM
Popa Tim's Avatar
Popa Tim
For a truck thats sat a whole year, I'd drain all the fuel and change the filter.
Old Apr 20, 2005 | 10:02 PM
DOHC330MustangGT's Avatar
DOHC330MustangGT
If you want more sound, put on a couple 2 chamber 40 series flowmaster mufflers. If your city doesn't do emiss tests, you can chop the catalytic converter off and make the flowmasters really sound good.
Old Apr 20, 2005 | 10:11 PM
turboguy's Avatar
turboguy
You could also change the Trans fluid and your fluid in your Differentials. Check your serpentine belt and all your hoses. Distriibutor. Plug wires. You could also drain the feul and change the feul filter like popa tim said. Also run a few bottles of feul injector cleaner through there.
When you lift the truck you can also change out all the bushings.
Old Apr 20, 2005 | 11:14 PM
azwolfman's Avatar
azwolfman
Thanks for all the advice. I never knew there was so much help out there. This site is #1.
Old Apr 21, 2005 | 12:02 PM
andym's Avatar
andym
I'd also like to add a suggestion or two, making the list:
Tranny fluid flush & filter change
air filter
breather filter
PCV valve
oil & filter
plugs, dist. cap, rotor, plug wires
coolant flush
fuel filter
differential fluids
flush brake fluid (should be done every two years)
check belts, hoses, and vacuum lines
Inspect brakes on all four wheels
Flowmasters with a nice dual exhaust would sound sweet on a 351. Also consider headers. They'll help with performance and sound.
Old Apr 21, 2005 | 01:30 PM
quicklook2's Avatar
quicklook2
check spring shackles, they rust away. radius arm bushings.
Old Apr 22, 2005 | 06:32 AM
02FX4Dude's Avatar
02FX4Dude
Don't forget to change the fluid in the transfer case.
