rear axle question
Old Apr 19, 2005 | 08:18 PM
87odell's Avatar
87odell
rear axle question
i have a 87 f 150, it has the 3:55 gear, my question is whether its an open or closed rear and whats the difference, is it stated on the tag, or on the door jam. thanks, excuse the ignorance
Old Apr 20, 2005 | 12:03 PM
RTM's Avatar
RTM
You have to look at the door tag and if the axle code has a letter and a number then it's a limited slip set up. If the axle code is just numbers then it's an open.
Old Apr 20, 2005 | 12:19 PM
Boss_358's Avatar
Boss_358
It also says it on the axle tag as well. If its still there that is. On the tag it would read 3.55 among all of the other numbers. If it had a limited slip it would say 3L55.
Old Apr 20, 2005 | 09:57 PM
87odell's Avatar
87odell
thanks for the response, i'll give it a look
