fuel injector cleaning kits
Old Dec 31, 1999 | 10:18 AM
thumper's Avatar
thumper
has any one tried the fuel inj. kits that snap on to the fuel line? and then you cut off the fuel pump, let the truck run off of this aresol can till it is empty?
Old Oct 12, 2000 | 12:04 PM
bgodkin's Avatar
bgodkin
I did this a couple times on my 1990 F150 351w. worked like a charm. This is actually the same thing that ford does when they charge you 250-300 dollars to clean your injectors. It woke mine up a lot.
Brad
Old Oct 12, 2000 | 12:36 PM
fordsrus's Avatar
fordsrus
Hi, Where do you buy this stuff at. I was going to pay Ford to clean them.
Old Oct 12, 2000 | 12:46 PM
RGAZ's Avatar
RGAZ
If you don't mind doing the labor yourself, I have had very good luck with pulling the injectors off and sending them to RC Engineering or a local diesel place where they blueprint and flow-balance all 8 injectors for $25 each. They usually have two day turnaround.
Basically, when they are done the injectors are BETTER than brand new. (new ones aren't flow balanced).
If not, I also have had good luck with running the tank as low as I feel comfortable then putting in two cans of Seafoam Carbon Cleaner in the tank. Then drive the truck till she runs out of gas (carry a gallon with you). She will smoke and not run real good until you dilute the carbon cleaner, but it really helps if you have really bad injectors.
Randy
88 F-150 custom 4x4 M5OD(POS) MSD coil 3"cat and back.
Old Oct 12, 2000 | 01:49 PM
bgodkin's Avatar
bgodkin
I borrowed the kit from a friend of mine that worked at the ford house. I bought the cleaner from Ford actually. it was a product by 3M I don't remember the actual name of it though. You might try a place like Autozone. they often loan tools out for free use when you buy a product requireing a special tool. Hopefully this helps.
Brad
Old Oct 13, 2000 | 08:33 AM
Motorcraftsman's Avatar
Motorcraftsman
Old Oct 14, 2000 | 06:29 PM
hotrodford_88's Avatar
hotrodford_88
I looked into doing this not too long ago myself. Bought the can of cleaner, and "thought" i had the right hose for the job at the house. I purchased a fuel pressure tester a year ago. But the hose wouldn't fit the can. The guy at the local parts house told me that the correct hose would cost me somewhere in the area of $70 - $75.
I then took it to a shop, and had the same thing done for $95. I think I might end up buying the hose anyway.
1988 F-150 Custom to XLT Lariat conversion, 5.0 EFI (formerly 300 I6), 5-speed M5OD, 3.08 rear gears (will be upgraded to 3.55's), Summit headers, Flowmaster muffler W/ dual 3.5" tips 24" long.
Pioneer CD, AC, Tilt, Cruise, Mobile Radio, Lightbar (Force 4 LP6000), Federal Signal PA300 Siren W/100W Siren Speaker. Caution Customizing in progress, Watch for flying tools & Parts!
7.3dieselMike
Bio-diesel, Propane & Alternative Diesel Engine Fuels
39
Mar 30, 2022 08:08 PM
93idi7.3
23
May 17, 2016 05:01 PM
Tdoyle03
Apr 1, 2015 02:05 PM
Michael Levy
15
Dec 17, 2014 05:12 PM
landmobile
Mar 16, 2012 10:20 PM
