79 f150 swb frame d44 front converted to 8 lug w/d60 in the back. still has coil springs.would the weight from my 6.9 diesel be too much?no hardcore 4 wheeling just a toy too play with.
Your 351M/400 (assuming) weighs less than 750 lbs. A 7.3L (6.9 should be the same) weighs 1400 lbs. wet. You're almost doubling the weight over your front axle. You might have to put in some 9 inch lift coils to keep the front from sagging (hypothetically speaking). A friend of the family put a 6 cylinder Perkins in a 75 2WD F250 and had to have custom coil springs made to hold the weight. You should've seen the truck when the engine came out once for an overhaul...this picture comes to mind (speaking of camber \----/ ).
I was seriously thinking about putting my Powerstroke diesel in my 73 2WD....that would be one fast sum-beetch. But, the engine weighs 1400lbs. and I don't think the truck would handle it...spindles, springs, frame, etc.
It would be worth a shot...make sure to document (with pictures) the swap if you do decide to do it!!
They are less than the 6.9. I am thinking 1000 to 1100.
Right-o!
The Cummins is considerably lighter than the Ford offerings( -450 to 500 lbs.) albeit quite a bit longer, so in a 73-79 ford, extensive mods are necessary to fit the engine lengthwise in the engine bay.
if your thinking of swapping in a diesel go find ya a cummins 4BT from an old Frito-Lay truck! most were backed by a TH400 and can easily be converted to a 4x4 tranny! the 4BT fits in the bay of an EB and doesn't weight it down too mcuh so that could be a good route to go!
theres a guy on Ebay called "cindythings", he has been selling Frito vans & 4BT's for a long time. a friend of mine has done business with him and he claims that he has the contract for California & is obligated to buy every van that is retired regardless of condition at a set price. He wouldn't give a price but we think it was around $1500/van & since they are solid aluminum ...they're probably worth $1000 in scrap aluminum never mind the 4BT's. He says he's never gotten one that didn't run as they all get maintained properly & safety inspected every year. He sells a complete van for $3000 or less & when you subtract the aluminum & consider they come with everything you need to convert your truck...right down to the hydroboost brakes... they're a pretty good buy. Some of them have the SM465 and others have the TH400 & you can adapt the same transfer case. Both transmissions are pretty solid behind a 4BT...no worse than their Dodge counterparts I'd say.
just my .02 worth
-cutts-
Bah, you just need to go with the good old 855 cummins turbo diseal, now theres a motor . I just happen to have the "small" turbo off my dads versatile from when he upgraded the turbo to boost the power from 300hp to 360-375hp, he still hasn't turned the injector pump up yet though.
Curious, how much power does one of those 4BT's put out (i'm assuming they're turbo'd)
The bread truck motors are rated at 107hp, I believe, and 250-300 lb.ft. of torque at around 15-1800 rpm. A 4BT with the P7100, with the right turbo/intercooler/compression, can make 175 horse and 500 lb.ft. of torque. I believe they'll turn more revs with a VE pump, but they're direct-injected, which is the biggest limiter of RPM...I think they're happiest between 1400-2400, but will spin faster than that...and a good pump guy can set the governor past 2500. But, being a very-long stroke 4-cylinder, I expect they'd shake fillings loose spun that hard.
all the 4BTs i have seen have turbos but i dunno for sure!
That little 4bt motor seems like i can put out some good power, something like that would be perfect for Ford to put in the 1/2 tons, just bump the HP to around 250 and you'd be good to go.
Yep the big cam motors are the way to (this is what we have in 2 of our tractors on the farm), the oil cooled pistons are a plus as well .
never knew much about diesels til i got my 6.9. learning something new everyday!I do like the idea of the 4bt in the smaller trucks. i think i will pass on the 79 chassis.for now ...
