Boxing the frame or not
Old 05-31-2008, 11:26 AM
W.Grills
W.Grills is offline
W.Grills is starting off with a positive reputation.
I was wondering if it would be better to completely box the frame, or just over the front ifs and rear axle. I see in all the magazines they only partially box the frame. Does the frame need to flex? Is it too stiff if fully boxed?
Old 05-31-2008, 01:25 PM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
The general consensus is to box a frame where an independent suspension can do it's job. So if you have an IFS, then boxing the front makes sense, as the IFS will do the work the frame originally did with leafs. Leafs are an up and down only movement. The frame allows one side to move up and down more or less than the other side, thus frame flex. So unless you have an IRS, then boxing the rear will only make for a harsher ride, since it won't allow the frame to flex.
Old 05-31-2008, 01:32 PM
Rokcrln
Rokcrln is offline
Rokcrln has a good reputation on FTE.Rokcrln has a good reputation on FTE.
I agree by boxing the frame it causes the suspension to do all the work. On these old trucks the frame was part of that suspension. On my 51 I am boxing the frame front to back and building a tubular center section but I am also doing IFS and IRS so I do not want any chassie flex. This will allow me to tune the suspension and not need to factor in the chassie flex.
Kevin
LFD Inc.
Old 05-31-2008, 01:58 PM
create's Avatar
create
create is offline
create is starting off with a positive reputation.
I boxed my the frame on my 55 F-100 and did the same thing with a tubular crossmember. Here is a pic of my setup . The tubular crossmember was original designed to prevent chasis flex, however it helpded beef everything up enough that I can put whatever kind of horsepower down I want.
(hopefully)
ben
Kevin
LFD Inc.
Old 05-31-2008, 02:51 PM
lowtrkn2k's Avatar
lowtrkn2k
lowtrkn2k is offline
lowtrkn2k is starting off with a positive reputation.
Where do you guys get the tubular crossmembers?
Old 05-31-2008, 03:41 PM
create's Avatar
create
create is offline
I made mine with a tube bender and a tube notcher.
Old 06-01-2008, 09:46 AM
W.Grills
W.Grills is offline
Thanks guys. I'm planning on a IFS and a solid rear axle with air bags. Wasn't sure how much to box. A bit less welding I guess.
Old 06-01-2008, 10:21 AM
fatfenders56's Avatar
fatfenders56
fatfenders56 is offline
fatfenders56 has a good reputation on FTE.fatfenders56 has a good reputation on FTE.fatfenders56 has a good reputation on FTE.
Please, box that thing in, boxing in sections just transfers the stress, frames that flex are doing work that the suspension should be doing
Old 06-01-2008, 03:55 PM
Rokcrln
Rokcrln is offline
Yep that is along the same idea I will be doing. I have been building tube chassies for a few years now both for the street and offroad. Here is one of my tube toys!
And a future 500hp street tube toy waiting for it's turn in the fab shop!
Kevin
LFD Inc.
Old 06-01-2008, 05:19 PM
3Mike6
3Mike6 is offline
3Mike6 has a good reputation on FTE.3Mike6 has a good reputation on FTE.
Kevin
LFD Inc.
Looks like an easy way to change the oil
Old 06-01-2008, 08:32 PM
dstruble's Avatar
dstruble
dstruble is offline
dstruble is starting off with a positive reputation.
I boxed mine completely. just made sense to me?? Runnin heidts superride II and heidts 4-bar ride is great!!
Old 06-02-2008, 12:26 AM
W.Grills
W.Grills is offline
The more I think about it. I think I want an air suspension. I was checking out No Limit this evening. I'm thinking it looks very good. Wondering how it will work the Flathead I'm using.
Old 06-02-2008, 07:10 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
remember that you need the associated parts for the suspension too.
compressor, air tank, hoses, valves. switches (or other control)..
I am having a devil of a time finding places for mine (and its only for the rear).
Tank under the pass door (where the battery used to be)
compressor (I think) under the rear fender next to the gas tank (outboard of the frame).
valves.. need 2 per air bag (1 up and 1 down).
Sam
Old 06-02-2008, 11:19 AM
W.Grills
W.Grills is offline
sdetwell, couldnt the compressor and solinoids fit under the bed along the frame on a bracket between frame and drive shaft?
Old 06-02-2008, 11:41 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
well, I have my exhaust partially up in there.. and the triangulated rear suspension parts.. amazing how much side effect (collateral damage!) one decision can have.
(and how little room there really is!)
I am constantly rethinking the triangulated rear.. as the mechanics are in the way constantly..
The long tube headers had to be high enough to get the tailpipe sections over the tranny cross member, else they would drag on speed bumps. (as I worry about my running boards).
the long lower trailing arms of the custom rear eat up a lot of frame rail space but provide good anti wheel hop/axle twist.
the triangulation provides good lateral stability, but take up a bunch of upper inner frame rail space.. and may block out the ability to take the exhaust up and over the axle.
(where the fuel line runs!) but I can't go out the side cause the trailing arms are in the way..
I can unbolt this thing in a heartbeat and go 4 link.. but wanted something different.. and its been an 8 yr journey.
had to raise the bed 3/4in to account for the drop when the bags are down and the c-notch. and am rethinking how I did that.. added a spacer on top of the cross members, which forces longer, non-standard bolts from the bed strips... adding a different spacer at the chassis would make things more normal..
anyhow, its more a complex puzzle than I had anticpated..
Sam
Quick Reply: Boxing the frame or not
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
