upgrade time?
Old Apr 17, 2005 | 09:01 PM
OrdoDraconis's Avatar
OrdoDraconis
upgrade time?
inline six 300 in a 87 f 150 EFI please tell me about good parts and point me to where i can get them i got the truck from my bro who passed away all he wanted was to fix this thing to be fast as it can go he left me the truck and 5000 dollars to fix it so................ the body is straight my brother sanded bondo and primed it..... what are some good places to look for interior aftermarket stuff motor upgrades ect. exterior aftermarket parts as well.
Old Apr 17, 2005 | 09:28 PM
I6power's Avatar
I6power
im really sorry about your bro. My inline 6 is carbed so i cant help you that much but ill do what i can. A starting point for motor upgrades is jegs or summitt. Everyone says headers is a good thing to do. I once read that the head on the 300 is like a cork. So headwork will be needed. But make sure you do a lot of thinking and research on this before you put anything on it. The 300 is a unique motor to say the least. Some parts can have adverse affects on it. But theres people here that know a lot more than meand theyll help you out. Good luck buddy
Old Apr 17, 2005 | 10:04 PM
Gerry Lutz Jr.'s Avatar
Gerry Lutz Jr.
Im also very sorry to hear about your brother . I have a 1988 efi inline 6 in my 77 ford f-150 pickup and,I've looked in to upgrades for it. To make it as fast as it can go and snazz that truck up for 5k in my opinion go to jegs or summit and buy a crate engine (351 or 460 would be perfectly suited). If you are beant set on building up the inline 6 it's not the motor itself you have to be worried about it's getting the computer to work with your upgrades. I beleive the speed density is only good for about 10% overbuild or underbuild so putting an extra 150 hp through it and expecting it to run correctly or at all is just not impropible. To get your computer to work right you are looking at dyno time and reflashing of your eec or converting it to another type of computer (1st gen lightning is said to work without to much of a hassle).
As for the motor itself if you still want to stay with inline 6 your looking at about 300 hp and 400ft lbs of torque with a very good build up. You would need a port and polish, new cam, bigger injectors (size depends on how much power you are expecting) Stock is 14 lb hour. Also would need to convert everything to arp studs heavier duty everything pretty much from pistons to rods so on.....
Look in to the "my built 300" thread, search for that he has a 300 hp 400ft lbs of torque dyno'd and built naturally aspirated. You can get some ideas from it but, don't expect to duplicate his build as your fuel injected and will require different things that a carb'd motor wouldn't. For ex. a 5.0 throttle body, bigger injectors bigger, electronic fuel pump probably and other shizzle....
In a more practical sense if you do plan on putting a crate engine in or building up a junkyard 351 or 460 or such it will be cheaper and much faster. getting 350 hp outa a 351 windsor is about as easy as putting a cheap set of aftermarket heads, new carb and, intake on it. Post back for more questions. as i've been researching how to build my efi engine for quite some time, and have aquired a lot of knowledge from the "experts/old timers on these forums".
Bamadawg63
Feb 10, 2012 07:17 AM
goldsmje
Sep 17, 2009 08:44 PM
honkytonk
Jun 13, 2007 12:34 AM
GBFD_EMS
Aftermarket Products
Oct 16, 2005 07:06 PM
tbirdsc
Mar 20, 2004 06:11 PM
