headers
Old Apr 17, 2005 | 09:42 AM
Hiflyer746's Avatar
Hiflyer746
headers
Hey guys, I just threw a set of long tube headers on my 89 150 302 5spd, and what a difference! I can't believe the power difference throughout the entire rpm range. Took me forever to build up rpms in 3rd and up, now its pretty quick. And I can definitely feel the power off the line too. Just thought I would let you all know.
Timmy
Old Apr 17, 2005 | 04:39 PM
F150'89's Avatar
F150'89
I installed a set of Flowtech "shorty" headers and a Flowmaster "40" series muffler and I can tell there is more power + I gained about 3 more MPG.
Old Apr 18, 2005 | 03:50 PM
towinchebbies's Avatar
towinchebbies
Great to hear!!! I've got an 89 F150/4wd/302/auto that I want to put long tubes on but haven't been able to find anyone to say which ones will fit. Which ones did you get? Where? Do they fit or was the install a PITA?
Old Apr 18, 2005 | 09:13 PM
DrewV's Avatar
DrewV
Headman has shorties that will drop in directly with your cureent exhaust
Old Apr 18, 2005 | 10:38 PM
towinchebbies
The current exhaust may fall off by the end of the week I like the extra torque of the LTs and it's much easier to fab up the rest of the exhaust (less bends).
Old Apr 19, 2005 | 01:58 AM
t_dickie's Avatar
t_dickie
I have heard where if you put headers on, your wise to change your plug wires to a 90 degree boot. The extra heat will burn up wires. Just what I've heard from people who had headers on their truck.
Trevor
Old Apr 19, 2005 | 02:47 AM
DrewV's Avatar
DrewV
I got my headers, and noticed some issues with my plugs... changed up to some high performance ones, no prob now
Old Apr 19, 2005 | 12:42 PM
Lumpy87's Avatar
Lumpy87
Same here except I got a SpinTech muffler. The only clearance issues I had was between the bolts and the tubes. It was hard to get anything but an open end wrench on them. Also if you use thick gaskets you can have problems getting the y-pipe to line up. Not an issue with full length headers since you probably have to fab up everything new from there back.
Hiflyer746: How did you run your exhaust? True duel, H-pipe, down both sides or both on the same side?
