Sponsored by: Real Truck
Abs
Old Apr 16, 2005 | 06:41 PM
moneypitt's Avatar
moneypitt
Abs
My ABS light is on no speedo and overdrive light is flashing I have changed the rearend lube and the sensor I need help please
Thanks Chris
Old Apr 16, 2005 | 07:04 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Thanks Chris
Did you change the rear ABS sensor or the VSS?
Old Apr 16, 2005 | 07:29 PM
moneypitt's Avatar
moneypitt
What is the VSS ?
Old Apr 16, 2005 | 07:44 PM
SpartanDieselTech
Former Vendor
What is the VSS ?
Vehicle speed sensor- these are known to go bad.
Obviously, whatever is wrong is affecting the performance of the transmission, or the O/D light wouldn't be flashing. The first thing I would check would be the VSS, and afterwards have the antilock module diagnosed at a dealer.
Old Apr 16, 2005 | 09:35 PM
moneypitt's Avatar
moneypitt
Thanks PSD I will check that out Chris
Old Apr 18, 2005 | 04:56 PM
moneypitt's Avatar
moneypitt
I had my brotherinlaw hook it to a scantool and it says VSS but I have been told there are more than one??
Old Apr 21, 2005 | 05:15 PM
moneypitt's Avatar
moneypitt
I went to the steeler and bought a senser that goes in the tail of the trans cost me $30.00 on my way home I noticed the truck was kinda dirty so I ran it trough the automatic car wash and my abs light went out and every thing is normal so I dont dare to replace the senser hoping to take it back any ideas what this trucks deal is ???????????????
THANKS Chris
Old Apr 21, 2005 | 05:35 PM
mrc59's Avatar
mrc59
ABS: Latin. Abus Balwat Santorum. English: Needs a wash.
Old Apr 22, 2005 | 06:05 AM
glafond's Avatar
glafond
abs
Check the connector at the rear differential.
Mine popped loose once, caused the same issues.
