Power stroke wont start
Old Apr 16, 2005 | 12:24 PM
E Alexander's Avatar
E Alexander
My son replaced the solenoid on his 97 F-250 heavy duty because it was clicking. After we trouble shot we found a bad starter. Problem is he didn't mark the solenoid wires and when we hook them up the way we think they go we have no power. Any ideas. Fuses are fine and batteries are charged with clean terminials.
Old Apr 16, 2005 | 06:07 PM
touchofgrey's Avatar
touchofgrey
Don't know if this is the same animal or not......but on my 2000 it's double white and double black on the bottom post. Hope this helps.
Old Apr 17, 2005 | 08:41 PM
believer45's Avatar
believer45
LINK TO PICTURE OF MY STARTER SLOENOID
My truck is a 95 - may be the same.
The post closest to the firewall has one wire, red, looks like 12 gauge that runs down into the wiring harness with the large single red wire from the other post on the solenoid.
The post closest to the battery has three large wires with fusible links (looks like two wires attached to the same terminal about 3" long that go to a single large wire at the other end - three of these stacked) then one red wire about 6 gauge or 4 gauge, a bit thicker than a pencil then one red wire about 14 gauge (may be aftermarket for the brake controller). The actuator wire to the small screw type terminal toward the top is red with black or blue tracer but has a terminal on the end that is set to push over the end of the small screw.
Hope these help out.
Dave / Believer45
Old Apr 17, 2005 | 09:06 PM
touchofgrey
Mine is way different........good job with the pic!
Old Apr 24, 2005 | 11:23 AM
E Alexander
Thanks
Thank you for the help. Put my son's together per believer 45 photo and we hit the road. Thanks for all the help guys.
Old Apr 24, 2005 | 08:10 PM
believer45's Avatar
believer45
Any time. Glad we could be of service.
Dave / Believer45
