Overdrive not working
Old Apr 16, 2005 | 12:02 PM
SimplyGreen's Avatar
SimplyGreen
Cool Overdrive not working
Uhm..
My overdrive switch is not working, what could be some problems that I could remedy?
The light doesnt turn on...
Old Apr 16, 2005 | 07:15 PM
touchofgrey's Avatar
touchofgrey
Green
Your problem could be something as simple as a burned out indicator light. It should only light when your out of overdrive. The switch to lock out the overdrive could be faulty also.
We need to know exactly what you are wanting to do.....and what year truck it's on.
We will be able to help you better, once we know these things. Thanks.
Old Apr 16, 2005 | 08:19 PM
SimplyGreen
I want to make sure my overdrive is working, either it's on overdrive or its off overdrive.
99 FORD F-350 PSD 4x4 AUTO - 181,000KM
Old Apr 16, 2005 | 08:28 PM
touchofgrey
I'd start with the light bulb then. It may be out.
Old Apr 17, 2005 | 11:10 PM
gramicko's Avatar
gramicko
I have the same problem on my 01' PSD, I've read the problem could be cut wires from the steering wheel column, adjustment.
Old Apr 19, 2005 | 01:41 PM
warrens250's Avatar
warrens250
Maybe check the fuse first? Some guys here know which one; I don't. Should be able to get that from the owners manual, though.
Warren
