Brakes
Old Apr 16, 2005 | 06:46 AM
ford429cu's Avatar
ford429cu
Brakes
I have a 99 ganger 4x4 that has a brake problem. For the past few months i haven't had rear brakes. I adjusted the rear brakes and that worked good for about a week. Then I put the truck on jackstands in the rear, adjusted the rear brakes again and then started the truck. It took so much pressure to stop the rear wheels with no load on them at an idle (auto tranny). I'm wondering it the wheel cylinders or the proportioning valve are no could. What test can I do to test each of these? Or if you guys think it may be something different.
Thanks
Jeff
Old Apr 16, 2005 | 11:26 AM
wresleu's Avatar
wresleu
Did you check the emergency brake?
Old Apr 17, 2005 | 10:09 AM
ford429cu's Avatar
ford429cu
The ebrake works fine
jeff
