TIMING? PROB?
Old Oct 30, 2000 | 04:16 PM
goosegos's Avatar
goosegos
TIMING? PROB?
I HAVE AN 88 WITH A 302, I SEEM TO GET CLOSE TO TIMING BUT WHEN I GET UP IN SPEED, 45 OR SO AND GET ON IT, IT SEEMS TO BE BOGGIN OUT LIKE THE TIMING IS NOT ADVANCING. IT IS FUEL INJECTED, ANY SUGGETIONS??
Old Oct 30, 2000 | 07:09 PM
hotrodford_88's Avatar
hotrodford_88
TIMING? PROB?
Have you disconnected the PIP when you time your truck, if not then that could be the problem.
Also try checking your PCV valve, and your filters under the hood. These could all cause the problem you describe.
I know mine definitely runs better after the other morning. I decided to do a little test since mine is bogging down, and has a bad hesitation when you take off. I disconnectde te vacuum line off of the EGR valve, and it runs 100% better. That one thing cured all of the runnning / idling problems I have been having. But I replaced the EGR & EVP sensor when I dropped the engine in the truck 2 years ago.
1988 F-150 Custom to XLT Lariat conversion, 5.0 EFI (formerly 300 I6), 5-speed M5OD, 3.08 rear gears (will be upgraded to 3.55's), Summit headers, Flowmaster muffler W/ dual 3.5" tips 24" long.
Pioneer CD, AC, Tilt, Cruise, Mobile Radio, Lightbar (Force 4 LP6000), Federal Signal PA300 Siren W/100W Siren Speaker. Caution Customizing in progress, Watch for flying tools & Parts!
Old Oct 31, 2000 | 11:09 AM
goosegos's Avatar
goosegos
TIMING? PROB?
thanks I found out about that yesterday-- I still get some fuel flow problem or something to that effect-i get the yellow light to flash right as the rpm gets up there before it shifts and that is when i feel like it is boogy feeling
Old Oct 31, 2000 | 06:53 PM
hecticgb's Avatar
hecticgb
TIMING? PROB?
