HELP WITH CODES
Old Sep 27, 2000 | 01:52 PM
jopey's Avatar
jopey
HELP WITH CODES
Old Nov 1, 2000 | 08:15 AM
goosegos's Avatar
goosegos
HELP WITH CODES
23; TP SENSOR OUT OF SELF TEST RANGE(THROTTLE POSTION?)
33; EGR VALVE OPENING NOT DETECTED(WHEN SHOULD IT? AFTER IT IS WARMED UP?)
14; PIP CIRCUIT FAILURE( WHAT IS PIP CIRCUIT??)
SUGGESTIONS APPRECIATED!!
THANKS!!
Old Nov 1, 2000 | 12:16 PM
huskeyone's Avatar
huskeyone
HELP WITH CODES
Sounds as if you need to run the codes again?! Make sure engine is at operating temperature, then turn it off. Then do the key on engine off test. At least that's how I did it on my 93 E150. Sounds like your vehicle is a little older as you are getting two didgit codes instead of three. Hope this helps just a little!!
John Hammell
93 Club Wgn/e-150
67 F250 Camper Special
Old Nov 2, 2000 | 11:14 AM
goosegos's Avatar
goosegos
HELP WITH CODES
i found out that the throttle position sensor was 180 off and the rest did clear up.it lacks a little power but it has a million miles.....
