Aerostar Ford Aerostar
Inside door handle
Old Apr 14, 2005 | 08:33 PM
Heykma's Avatar
Heykma
Question Inside door handle
I went to get out of the van and my inside door handle popped and doesn't work.So I rolled down the window and opened it from the outside.What normally breaks,any suggestion would be a help.I don't want to get to the fun stuff like shocks,steering rack and barkes until I can get in and out.Thanks Kathie
Old Apr 14, 2005 | 10:45 PM
krankshaft's Avatar
krankshaft
Well if your door handle is like one of my cars probably the metal linkage popped out of the handle assembly or the retainer broke.
I can't compare to my Aero because it has no power windows or doors and I think the handle assembly is different.
Here is how it is on one of my cars that has power locks and windows I think the design should be similar.
There is a metal linkage that connects the door handle to the latch assembly. There should also be a piece of plastic that clips onto the metal to stop the linkage from falling off the inside handle.
The outside handle has its own linkage to the latch so that will still function fine.
To fix this you will need to remove the door trim panel and see what happened to the linkage if it just fell out of the inside handle pop it back into the handle if the linkage retainer broke then the linkage will just fall out again pick up a new retainer at the Ford dealer and you should be set.
Old Apr 14, 2005 | 10:50 PM
Heykma's Avatar
Heykma
I have the door panel off now and it has a plastic finger that is made on to the inside handle that moves the mechanism that opens the door.So I tried putting the finger back in and it pops right back out. I guess I'll sleep on it and see what tomaorrow brings.Thanks for the info.
