Where does the vent hook to?
Old Apr 14, 2005 | 06:01 PM
tastyklair's Avatar
tastyklair
I have a Carter AFB comp series 625cfm carb. There is a vent valve coming off the top that looks just like the fuel inlet. Where does this go?
Old Apr 14, 2005 | 11:01 PM
LxMan1's Avatar
LxMan1
It would go to a charcoal canister if you have one. If not, plug it off.
Old Apr 15, 2005 | 02:24 PM
tastyklair's Avatar
tastyklair
Thanks. One other question. Unlike the Edelbrock, this Carter also has a vacuum port at the bottom of the electric choke pot. What is that for and is that a full vacuum or a ported?
Old Apr 16, 2005 | 08:33 AM
LxMan1's Avatar
LxMan1
It should be full vacuum. Does it have a port on the top of the choke? Sometimes they loop around to pull ait into the choke assembly. If not, I would just plug it too.
