Fbina109
Old Apr 14, 2005 | 04:12 PM
FBINA109's Avatar
FBINA109
Fbina109
I have a Banks "Air Ram" filter setup. Goes into the Ford air box and has a flat K&N filter. This was on the truck when I bought it. Being an avid reader of the forum, my question is this a good setup? Any thing I can do to make it better without dismantling, or is it good enough as is?
1999.5, F250, Lariat. X-Cab, Long Box, Auto, Banks Bighead w/Exhaust, Banks Trans-Command and Gauges
Old Apr 14, 2005 | 04:39 PM
touchofgrey's Avatar
touchofgrey
The K&N flat filter has had some sealing problems around the outside gasket of the filter in some air boxes. A light film of petrolium jelly or common grease applied to the gasket may help.
What you want to look for: check to see if you are getting any fine dust in the intake tube going to the turbo. If you are.....then you've got a leak. You will see a light film of oil in there.....that's from the EGR that is plumbed into the intake, and is common on stock trucks. But there shouldn't be any dirt. Hope this helps.
George84
Mar 26, 2012 08:03 PM
aocabrown
General Diesel Discussion
Nov 6, 2007 08:51 AM
hood
Modular V8 (4.6L, 5.4L)
Feb 24, 2006 06:58 PM
FBINA109
Nov 16, 2004 10:13 PM
