PARKING BRAKE BROKE?!?!?!?!
Old Nov 1, 2000 | 02:07 AM
KevinT's Avatar
KevinT
When parking truck today, kinda on a grade I set the brake really hard so it wouldn't roll and CRACK brake goes another 1" or so in and bottoms out, pulling on cable wont release the brake, but pulling cable and yanking on the pedal brought it back out and a small metal cylinder with a round crack on the side of it fell out from the assembly...brake light stayed on and rear brakes smelled like burning when I got it home...HELP!!!
taking to a garage tomarrow, but if this is fixable myself it would be WAYYYY cheaper!
1995 F150XL - Reg cab/bed, 4.9L, 5-speed, Metallic Navy Blue/Gray int.
Mods: Topdeck bed lid, protecta bed liner, 1200 watt amp, 2 10" Rockford Punch Subs, sony cd-player, K&N Filtercharger, Flowmaster 40 series + custom exhaust (no visible exhaust exit) BFG A/T 31"x10.5"R15 & Rancho RS5000 shocks
Old Nov 1, 2000 | 02:21 AM
PAUL_2's Avatar
PAUL_2
I wouldnt advise driving it any further to reduce the amount of repairs you will have . Im sure the cable seized at some point which locked the rear brake shoes . More than likely you are looking at new brake shoes , new cables & any associated hardware & possibly new brake drums if they cant be resurfaced . Using your parking brake everytime you park your truck is a good idea , it keeps the cables free of corrosion .
Old Nov 9, 2000 | 12:01 PM
hotrodford_88's Avatar
hotrodford_88
Old Nov 10, 2000 | 02:27 AM
bigsix's Avatar
bigsix
This happened to my '81 F100, with the qualification that I don't remember FOR SURE if the pedal dropped an additional one inch. I can tell you, however, that due to setting the brake really hard, a piece of the Parking Brake mechanism bent. The good news is, I bent it back, and the brake worked fine (for a year!). The bad news is, it's happened again. You have to remove the mechanism, and you'll see what I mean (at least on an '81). I'm sorry I can't be more specific, but I don't remember exactly which part it was, but it was easy to bend back.
Old Nov 10, 2000 | 02:49 PM
KevinT's Avatar
KevinT
the part that broke on mine was the front parking brake cable, a $15 part so I got off easy
Mods: Tanno cover, bed-liner, 1200 watt Crunch amp, 2 10" Rockford Punch Subs, sony cd-player, K&N Filter, Flowmaster 40 series w/ no visible exhaust exit, BFG A/T 31"x10.5"R15 & Rancho RS5000 shocks
