Sponsored by: Real Truck
Gear change
Old Apr 15, 2005 | 07:53 AM
Size Matters's Avatar
Size Matters
Beemr - Thanks for clearing that up.
I am still not sure if TruSpeed can be used on other vehicles. When I ordered it for my SD, it came with a calibration chart that included adjustments for gears. Since the SDs do not need that, then I would "assume" they work for other vehicles. Call SuperLift and find out for sure though.
Old Apr 15, 2005 | 08:26 AM
iskybantilus's Avatar
iskybantilus
i think beemr is a little mixed up in what he typed. if the sensor were picking up off the pinion gear as stated, then it would need to be reprogramed.
Reason - speed of pinion gear is same as output of transmission. this will increase with your new gears to maintain same axle speed, hence the increase in "power" or torque through greater mechanical advantage, the speedometer would now read this higher rate and interpret it as you are going faster due to its algorithm.
If the sensor is picking up off the ring gear sensor, then it is picking up a speed relative to axle speed. if this is the case, then it will pick up the same axle speed at given ground speed, even though the engine is now turning faster.
In either case tire size will effect speedometer reading.
Old Jul 11, 2020 | 06:08 PM
WidgetTrac's Avatar
WidgetTrac
Originally Posted by Size Matters
I have a TruSpeed on my truck. The guide for it gives you adjustments for GEAR or TIRE or GEAR & TIRE changes. I do not think they would have that option if gear ratio did not affect the speedometer.
I can't say if the 10.25" rear is the same, but I swapped the open diff for a Trac-loc in my '01 9.75", and the Speedo sensor picks up off a toothed ring that is pressed onto the carrier, immediately adjacent to the ring gear. the ring gear, carrier, axles & tires all rotate together (except when turning, or one-wheel spin), so the Speedo sensor is more or less measuring how fast the rear wheels are turning, so the speedometer is not affected by a gear swap - only by changing tire size.
the TruSpeed probably wants to know BOTH so that it can calculate distance covered per driveshaft revolution. I don't know much about the PCM, but it seems like it would be beneficial for the PCM to have the correct values as well.
Old Jul 12, 2020 | 02:57 PM
Dave54000's Avatar
Dave54000
I am doing the same gear swap are you happy with performce increase thanks
Old Jul 12, 2020 | 03:37 PM
Desert Don's Avatar
Desert Don
Maybe a new thread is in order here.......this one has been dead for 15 years!
Old Jul 12, 2020 | 04:57 PM
WidgetTrac's Avatar
WidgetTrac
yep! ...I did a search, and this one came up - forgot to look at the dates.
I started a new thread in 99-03 F150 forum, looking for feedback on mods I'm planning :-)
or maybe it was in 4.6 & 5.4 motor forum, I forget
V10man
Oct 9, 2018 09:29 AM
bass-n-fire
1997 - 2003 F150
Mar 8, 2016 06:04 PM
muscletruck7379
Jun 20, 2009 05:15 PM
bigric
Apr 2, 2004 10:12 PM
Rew
Sep 19, 2003 09:29 PM
