Cold Idle Problem
Old Nov 7, 2000 | 12:12 PM
cgl's Avatar
cgl
Cold Idle Problem
Old Nov 14, 2000 | 09:44 AM
dougg's Avatar
dougg
Cold Idle Problem
I am having a cold Idle problem with my 92 f150 302. It is ether a high idle or stalling. I know in other makes there is a valve (I forget what it is called) that allows air past bypass the throttle body when the engine is cold to maintain the proper idle. Does the 302 have such a devise? And where is it?
Thanks
Doug
Old Nov 14, 2000 | 02:59 PM
jeepls's Avatar
jeepls
Cold Idle Problem
The idle air bypass valve is located on top of the throttle body. It's near the flexible hose from the airfilter box. If you take it off, see if it is dirty inside. You can clean it carefully, try not to get anything in the electrical part of it. I've cleaned them with spray carb cleaner. It should help.
Old Nov 15, 2000 | 10:06 AM
dougg's Avatar
dougg
Cold Idle Problem
>take it off, see if
>it is dirty inside.
>It should help.
Just what I needed to know.
Thanks
Doug
