gear oil
Old Apr 13, 2005 | 09:08 AM
oldmanbergie's Avatar
oldmanbergie
gear oil
I have a 1991 ford f450 460 gas with a 5 speed stick 5 gear over drive. I draned out the oil from the transnission the other day, and the oil looked like ATF (automatic transmission fluid). I installed 85/140 gear oil. The shifting has greatly improved, i can now shift into 2 gear at a dead stop. before i had to shift before the truck was stoped. It was verry dificalt to get into rev,first and second at a dead stop, it was like the gears wouldn't stop turning inside the transmission with the clutch depressed. some time i would just turn off the engine then shift into gear and restart the engine. Is a common problem with this transmission?? Will the 85/140 oil hurt this transmission??
THANKS IN ADVANCE oldmanbergie
Old Apr 18, 2005 | 08:09 AM
oldmanbergie
Question gear oil
need help
