I have a 96' explorer 4-door, with the keyless entry....first the doors would not lock using the key-fob., but the alarm would enable, and at this same time the autolock feature stopped working, i tried the enable/disable sequence in the manual but it would not finalize with the two horn beeps or whatever it is..now about 4 months later the locks will not lock using the lock button on either drivers or passenger doors, the one in the back is the only one that will lock the doors, they all including the key-fob. will unlock the doors......
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
