flexplate
Old Apr 12, 2005 | 01:08 PM
JCastellaw's Avatar
JCastellaw
flexplate
What's the difference between a flexplate and a flywheel. Does anyone have a picture of a flexplate?
Old Apr 12, 2005 | 05:40 PM
stuart1's Avatar
stuart1
A flex plate is used with an automatic transmission.
A flywheel is used with a standard transmission.
About 50 pounds difference.
Old Apr 13, 2005 | 12:49 AM
Hooker Bob's Avatar
Hooker Bob
The flex plate also serves as a cushion between the torque converter and the crank. It absorbs shock load during take off and during shifting.
Although this load is not as harsh due to the slight hydrualic cushion in the pump, when compare to the load put out by a manual transmission. It is still quite a lot of force to absorb.
Except for dualmass types, flywheels rely on the springs in the clutch to absorb this shock load.
Without this shock absorbing ability you'd be breaking the small converter bolts off
or stripping the center out of your clutch quite regular.
Pat
Old Apr 13, 2005 | 09:20 AM
JCastellaw's Avatar
JCastellaw
Any pictures of a flexplate?
Old Apr 13, 2005 | 02:41 PM
stuart1's Avatar
stuart1
flexplate
Old Apr 13, 2005 | 03:29 PM
kotzy's Avatar
kotzy
More than the shock load the plate takes up the assembly differece between the centerline of the crank to the centerline of the conveter/ transmission input/ stator
shaft. That is held in place by the dowels in the engine/ bellhousing. This alignment is not perfect sometimes running out nearly .010 and the connection cannot be ridgid. If the unit constantly breaks plates misalignment is the cause.
