axle hub
Old Apr 7, 2005 | 07:46 PM
PIKE's Avatar
PIKE
axle hub
I have a 1978 F350 with dual rear wheels.The eight 7/16 bolts that hold the axle in will not stay tight,even with loctite and new hardened bolts.The threads are worn out,and I have tried to find a new hub or a used one,but no luck in my area.Anyone have any ideas for repair or replacement?
PIKE
Old Apr 11, 2005 | 10:04 AM
73Custom's Avatar
73Custom
Do you have enough room to double nut them? Or just replace the studs and nuts, not the entire hub.
Marty
Old Apr 12, 2005 | 11:16 PM
PIKE's Avatar
PIKE
axle hub
I am going to try a bottoming tap,new studs, and either loctite or jb weld.there apears to be room for about a 2 inch long stud and the bolts that were in there were only 1.5 inches long.Any other ideas?
Old Apr 13, 2005 | 12:10 AM
Fordbronco69's Avatar
Fordbronco69
Infidel
New studs sounds like the smartest way to go...its almost garunteed to cure your problem.
My dads Chevy 3500 duel rear wheel studs where coming loose just last week....all of them but 2 FELL OFF!(45mph) rounded the rims out, studs where ok but its not worth having them fall off again and with atleast 2 tons of tools in the toolboxs it will ruin your day.
Old Apr 13, 2005 | 05:15 PM
rclarke's Avatar
rclarke
Check your rear end housing for straight. The only thing I have ever seen that broke or loosened the axle studs or bolts is a bent housing. The easiest way to check it is pull both axles and look through the housing. If it is bent it should be fairly obvious.
Eileen Pike
Bronco II
May 7, 2013 01:15 AM
whporwil
6.4L Power Stroke Diesel
Oct 10, 2009 10:24 PM
PIKE
Garage & Workshop
Feb 2, 2008 02:55 PM
Mike W
General Automotive Discussion
13
Jul 30, 2004 07:09 AM
