help finding rings
Old Apr 12, 2005 | 01:04 AM
bootie's Avatar
bootie
help finding rings
i'm looking for some +045 rings for my merc motor (8rt) does any one know where i can find some - (only need 4 top rings) but a full set would be better
Old Apr 12, 2005 | 06:29 AM
kotzy's Avatar
kotzy
Go to the Hastings sit on the net, I'm sure you can email them with your needs. I do
have a question how did you end up with a .045 bore?
Old Apr 12, 2005 | 12:20 PM
dodgedh2's Avatar
dodgedh2
I'd like to know that also. That's an odd overbore size. Typically, it would be .010", .020", .030", or .060" overbore.
Old Apr 12, 2005 | 02:53 PM
SasquatchF-250's Avatar
SasquatchF-250
try National Parts Depot
Old Apr 13, 2005 | 01:15 AM
bootie's Avatar
bootie
we were talking about that at work and wondered if it had been a case of unfinished piston to a bore thats been cleaned up it has ford and maDE IN CANADA stamped on it
Old Apr 13, 2005 | 07:08 AM
kotzy's Avatar
kotzy
Years ago it was not uncommon to bore engines .040. A lot of things were done when
dollars and resources were tight. Semi fiinshed pistons were ground in local shops to fit
what ever, the same with cranks and semi finished inserts. Todays labor cost would
make this impractical. The only thing I found odd was the extra .005. Perhaps it
was a mistake on one hole and they went on and made them all that way, or the pistons
were at hand as they and not correct. Sad part is you have the mess of finding rings.
Old Apr 13, 2005 | 02:19 PM
bootie's Avatar
bootie
i'm trying to find some thing that will work so been looking at various rings but most of the japenese stuff that is similar uses a 1.5mm thin ring
Old Apr 13, 2005 | 02:47 PM
mtflat's Avatar
mtflat
You might try Red's Headers online. They're very helpful folks who actually work with and run flatheads. If Red can't supply the rings he'll know who does I bet.
Old Apr 13, 2005 | 03:11 PM
kotzy's Avatar
kotzy
Since it is only .005 you may get away with a .040 set. Std rings take care of wear and
taper up to almost .010, and each size above it would handle up the .010 above it. We don,t see cylinders tapered like that any more, as a matter of fact you have to think were you have your ridge reamer stored the wear just isn't there . That was one of the reasons I suggested Hastings they may have a semi fitted ring which you would have
to file the end gaps to the cylinder.
