interior mods
Old Nov 25, 2000 | 06:33 PM
barryo's Avatar
barryo
interior mods
I just bought a 1982 f100. It needs a little refreshing, but otherwise is a really strong truck. (Especially for the 500 bucks I paid for it). I'd like to take the bench seat out and put a 60/40 split bench or buckets in it. Do any of you out there know of any seat that directly replaces it? I also had a thought about the floors. I spent this afternoon pulling the original floor mat and the insulation out. What do you guys think about using spray-in bed liner for the floorboard? This will primarily be a work/boat-pulling truck so I don't want carpet. Any response is GREATLY appreciated.
Thanks,
Calvin
Old Nov 25, 2000 | 08:08 PM
fatforty's Avatar
fatforty
interior mods
Hi, any of the newer trucks up to 96 will definitely fit including captains seats from the bronco they even have a plastic console between them if you want to use it.
John (fatforty)
i967mustang(No Email Addresses In Posts!)
Old Nov 25, 2000 | 10:13 PM
barryo's Avatar
barryo
interior mods
John,
Thanks for the reply. Do you know if the seats up to the 1996 will fit my truck using the same bolt pattern? Thanks for the help.
Calvin
Old Nov 25, 2000 | 11:20 PM
fatforty's Avatar
fatforty
interior mods
Hi, the seats should have the same bolt pattern unless you use captains seats then you would have to drill the extra two holes for each seat. John (fatforty)
Old Nov 25, 2000 | 11:25 PM
fatforty's Avatar
fatforty
interior mods
Hi Calvin, if you take out the insulation and spray the floor you will get alot of road noise, if you want it to be quiet you should put back the vinyl mat with insulation or go with carpet. I have an 86 lariat as a work truck and the carpet stays pretty nice just have to sweep it out once in a while.
John (fatforty)
Old Nov 27, 2000 | 10:03 PM
barryo's Avatar
barryo
interior mods
John,
Thanks again for your input. I think I'll be junkyard shopping this weekend. I'm going to go ahead and order a new matt also instead of the spray in. Thanks once again.
Calvin
Old Nov 27, 2000 | 11:34 PM
hotrodford_88's Avatar
hotrodford_88
interior mods
I ripped the vinyl mat out of my truck. The previous owner must have gotten the insulation underneath it wet because it smelled constantly, no matter what I sprayed in the truck.
I ordered a carpet kit from summit racing (yes, they carry carpet kits for those that didn't know), the carpet only ccost me $100.00 and I added a little more insulation underneath the seat where there wasn't any on the carpet itself. Man what a difference. 100% quieter much cooler in the summertime, and warmer in the winter. The carpet has been in a little over a year now and has held up well. I wouldn't hesitate ordering another carpet kit from them.
Plus if you order the vinyl mat, it won't cost you near what having bedliner material sprayed in would have!
"You can always tell a Chevy owner, You just can't tell them very much."
Old Nov 29, 2000 | 11:10 PM
barryo's Avatar
barryo
interior mods
Thanks hotrod,
I'll take the advice for sure. I just need to clean up the floorboard first. I have so many things I want to do and so little time and money to do them. I'm trying to do the important stuff first. Thanks again.
Calvin
Old Nov 30, 2000 | 07:25 AM
hotrodford_88
interior mods
Yeah plus it's hard to find anything to customize an 80-96 Ford pickup. Well at least the 80-91 models.
I found some custom hoods, but they run a little expensive for my taste.
Here's the one I really like. It's called the GT-500, & it's made by usbodysource. At $539.00 I think I'll be waiting a while to buy one!
http://www.usbodysource.com/tfth-88.gif
Old Nov 30, 2000 | 07:26 AM
TallPaul's Avatar
TallPaul
interior mods
tonysal
Nov 22, 2016 06:49 AM
Bulldog187th
27
Aug 28, 2016 01:30 PM
darmento
Jan 20, 2016 10:49 AM
kadrocker
Mar 7, 2015 06:02 PM
96f-250
Dec 8, 2009 04:59 PM
