Sheetmetal interchangeability
Old Dec 6, 2000 | 03:22 PM
dzrtdog's Avatar
dzrtdog
Is the front sheetmetal interchangeable between the '80 - '86 bodystyle trucks, and the '93 - '96 bodystyle? Also, are the body lines similar?
Thanks
Don
Old Dec 6, 2000 | 04:38 PM
Pastmaster's Avatar
Pastmaster
I'm pretty sure they are interchangable. You should try to find a whole clip. The piece under the windshield where the wipers come from is different on later models, I don't know whether that is interchangable though.
Pastmaster's 1993 XLT 5.0 E40d 3.55LS Normal Cab/Long bed Loaded from the factory with aid of...MSd 6a ign/s.p. wires, blaster coil, Hypertech Chip, K&N filtercharger, Cat-back dual exhuast w/o mufflers, 3.5", echo tips, Accel distributor cap, Dark Mocha over light mocha. 5% Dark tint, Alpine Cd player/remote, Pioneer speakers.
toydestroyer1(No Email Addresses In Posts!)
Old Dec 6, 2000 | 06:18 PM
dzrtdog's Avatar
dzrtdog
Thanks,
What I am planning to do is run late model fiberglass fenders and bedsides on a '82 prerunner I am building. Hopefully I can make it work.
Don
Old Dec 6, 2000 | 06:38 PM
fatforty's Avatar
fatforty
Hi the body lines are close, the fenders and hood will bolt on the earlier truck but you will probably need the radiator support from the newer truck so that all the bolts line up in the fenders. JOHN (FATFORTY)
Old Dec 6, 2000 | 11:25 PM
hotrodford_88's Avatar
hotrodford_88
The body lines on the doors and front fenders will line up, but the bed won't look right, unless you have a late model bed on your truck.
Good luck.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
[link:www.geocities.com/westlake_vfd/Westlake.html|Westlake VFD Website]
Old Dec 7, 2000 | 12:54 PM
fiddy's Avatar
fiddy
you'll need the cowl piece, and definitely the core support in order for that to work.
Old Dec 7, 2000 | 06:08 PM
dzrtdog's Avatar
dzrtdog
Would I be able to get away with the stock cowl if I use a after market fiberglass hood with a 2" raise?
Old Dec 7, 2000 | 06:23 PM
fatforty's Avatar
fatforty
Hi, I would find the style truck you want to use and measure the cowl, I can't understand wht you would need it if you are useing fiberglass the cabs are all the same from 1980-1996 even 1997 on heavy duty 250's and 350's the cowl is a different design but should be the same dimensions. JOHN (FATFORTY)
Old Dec 7, 2000 | 08:05 PM
fatforty's Avatar
fatforty
