Power problems
Old Apr 10, 2005 | 07:52 PM
Arauthator's Avatar
Arauthator
Today I had to replace the alternator and battery coming back from a fishing trip. I was getting no power going up any hills. Ran the battery down while running down the road even. Got a jump start, drove to the nearest gas station and she quit on me right before the drive. Started it up, had enough power to barely scoot into the parking lot, waited for my parts and tools to arive, Replaced all this, did just fine for about 20 minutes, then I started to get the same old power drag like it's trying to flood out. Just not as severe as it was before I replaced those 2. The alternator and battery was definately part of the problem, but now I'm starting to think it may be the spark plugs too. I feel the fuel pump is fine, unless it's trying to work out some air bubbles maybe, but it feels like it's not getting any gas and it's sparatic, with no consitency at all. Any idears?
Last edited by Torque1st; Apr 11, 2005 at 01:00 AM. Reason: Making new thread for hijacker
Old Apr 11, 2005 | 01:02 AM
Torque1st's Avatar
Torque1st
Posting Legend
New thread created.
Old Apr 11, 2005 | 09:24 AM
73Custom's Avatar
73Custom
Since you are suspecting the charging circuit, test that first. With engine running, test with voltmeter on + and - battery terminals. You should get 12.5-14.5 volts with the engine reved to about 2500rpms. If not then look further. Did you replaced the voltage regulator? I always replace this when replacing the alternator, as it is what tells the alternator how much to charge.
If you had low power, your spark would get weak and it would start to act flooded.
Let us know what you find.
Marty
Old Apr 11, 2005 | 09:35 AM
savage066's Avatar
savage066
i agree with marty. the voltage regulator is quite often overlooked, and just as often the source of the problem. they only cost 10 bucks or so, and installation is a 2-minute job.
Shutech
Apr 21, 2015 09:31 PM
radmacks
Aug 29, 2014 07:31 PM
dyingtolive
Aug 1, 2012 07:37 AM
ErrorS
1978 - 1996 Big Bronco
16
Dec 29, 2010 03:58 PM
dland
Oct 16, 2002 08:23 AM
