Intake for 94 4.0?
Old Apr 10, 2005 | 12:23 PM
tbiker99's Avatar
tbiker99
Intake for 94 4.0?
The stock Air filter system looks extreamly restrictive. Anyone know of a CAI or high flow set up for a 1994 4.0 Ranger?
Additionally, anyone know what I could/should expect from a CAI on this truck?
Thanks
tom
Old Apr 10, 2005 | 03:01 PM
Hank85713's Avatar
Hank85713
I got mine from street smart design, its for the 95 and later 4.0. The difference is that the 95 on have a lower upper rad hose location, my tube sits on top of the rad hose but no big deal. If when I need to changes rads I will go with the later model but until then mine is working just fine.
They have pics on their website do a search as urls will not post right here.
Old Apr 10, 2005 | 03:26 PM
thorman's Avatar
thorman
if your handy,make you own,i did for my 03 4.0 .much cheaper and satisfying.
Old Apr 10, 2005 | 03:31 PM
thorman's Avatar
thorman
i did'nt find a cold air so i made own,using stang banger tricks i learned through the years and a large k&n round tapered filter in stock at autozone for 45$ bucks.e-mail me if you want the details.works well!!
Old Apr 10, 2005 | 03:56 PM
thorman's Avatar
thorman
P.S. the air box is 75% of the restriction at least.just fix the part from the airflow sensor out and leave the stock part intact from the sensor to the throttle body.that part works well and would require more work to change than worth in gain.there is also a K&N slightly smaller that has a metal flange that you could drill 4 holes in very carefully and bolt directly to stock flow sensor,but it could get wet and dirty faster but this is how many kits come(naked filter i call these) good for street machines on road,but no cold air,still better than stock box
Old Apr 10, 2005 | 07:25 PM
HogTied's Avatar
HogTied
Hey thorman, I've been reading a few of your posts and I notice a couple of things:
1. Learn how to use the "EDIT" function -- make less posts (stop replying to yourself)
2. Learn how to use the biggest key on your keyboard the SPACE key.
Old Apr 10, 2005 | 08:08 PM
thorman's Avatar
thorman
Smile maybe i should have read the directions
but by definition a gearhead never reads directions,right.I shall look into the proper rules and manners for this site.I was so excited to talk to fellow types i skipped over stuff.
Old Apr 10, 2005 | 08:20 PM
GrayRanger4x4's Avatar
GrayRanger4x4
The Ford stock air intake will flow more air then you need for a stock v6 engine.If you went to do any mods just get a high flow air filter {like a K&N} that replaced your stock one.
Old Apr 28, 2005 | 10:06 PM
w_pinkerton's Avatar
w_pinkerton
go to www.ifab.net, i got just the filter and adapter for my '93 4.0, but they do have and actual intake for our year. the 93 and 94 years have the same intake set up and everything. you could also try www.kkm.com
Old May 2, 2005 | 12:34 AM
HogTied's Avatar
HogTied
http://cgi.ebay.com/ebaymotors/ws/eB...category=38634
[*img]http://i19.ebayimg.com/01/i/03/c4/5d/06_1_b.JPG[/img]
